DC - EF brake swap
I am wondering if you can bolt the dc integra rotors, caliper & caliper mounting brakets to an ef front knuckle.. Im also doing the rear disk swap & im swaping the master cylinder, & proportuning valve to do the rear disk swap the correct way.
Im keeping my D motor but I wanna get the aftermarket stock "big brake kit" thats why I needa know if the front brakes will bolt to an ef front knuckle. |
Re: DC - EF brake swap
no, you cannot bolt up the 94-01 integra LS/RS/GS/GSR front caliper & rotors
onto your 88-91 civic EF front knuckle (unless it is a 90-91 civic EX front knuckle; which accepts 10.3" front rotors, same size as found on any 90-01 integra * excluding ITR) > if you do not have the 90-91 civic EX front knuckles then you have 88-91 EF DX knuckles, which use 9.4" front rotors. here's a few options for upgrades on DX knuckles: 1. www.fastbrakes.com sells a bracket which mounts the DC integra front calipers onto a DX knuckle with a larger rotor set-up. honda-tech member BE2 specializes in OEM honda brake upgrades kits. 2. here's a link for: s2000 front calipers, which use 11" rotors on a DX knuckle http://hondamarketplace.com/showthread.php?t=2569691 https://img11.imageshack.us/img11/7641/s2g60post.jpg 3. Acura CL brake upgrade for 9.5" Civic Brakes > 11" rotor http://hondamarketplace.com/showthread.php?t=2756883 https://img28.imageshack.us/img28/829/cldx11.jpg |
could i use ex knuckles off of an eg hatch
Originally Posted by kingsnake692005
(Post 42212073)
front knuckles are better suited for EG civics |
I have an ef/ed hatch & i was wondering if the eg knuckles will fit my hatch
for the best alignment results on any 88-91 civic/CRX EF,
use 90-91 civic EX or 90-93 integra DA front knuckles (complete with calipers)
Originally Posted by BrakeExpert
(Post 35922658)
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas. Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve. https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/da-knuckles-vs-si-knuckles-ex-knuckles-big-brakes-2140287/ |
http://i5.photobucket.com/albums/y18...r/DSC00749.jpg
s2000 calipers and carriers with 3mm milled off the back on 12" civic type R (ep3) discs on CRX SiR knuckles |
I have the DA front brake conversion from fastbrakes, works great!
anyone got pics to confirm an s2k caliper on an ef(stock cx hub)? And what size rotor from what car?
what if i have 90 lx knuckles on my 90 lx sedan can i do it?
I got and 90 ef si that I want swap with dc 4door brakes. I also have tokico struts and neuspeed springs from a 93 del sol that im going tobe putting on. just wondering if all this will work
