Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu, Wid
Old 05-03-2008, 01:43 PM
blufke's Avatar
Default Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu, Wid
Hi,
Doing some long overdue garage cleanup. I am located in Santa Barbara CA, so pickup is always an option if you are local, and mandatory on some of the parts(ie Azenis). I'm always willing to discuss price within reason.
680CC injectors. They were cut to try and make them fit a stock honda rail. Too much material was cut away, and they need some more plastic on there to push the o-ring into the rail. I ran them this way for a while, but didn't have too much confidence in their ability to hold a reliable seal. But some effort and they wil be good reliable injectors. $125.
P72 Headgasket. Brand new. $75.
Sport Comp Pyrometer Gauge with wiring and sensor. I bought it used but never used it myself. $75.
Apex'i Fancy shmancy Dual Fannel(?) Filter. It has some light damage(pics). $50.
AEM Bypass Valve. Has a little dent in it, and a 1" slice in the foam that is not going to affect its performance unless you separate it by hand. which you won't do while you are driving . $20.
P28 ECU. Modded already(see pics). Only needs 2 $0.15 capacitors and one $0.50 chip(will go into DIP chip socket). You only need to solder in the capacitors. See here: http://www.superhonda.com/tech....html . $90.
Drag Intercooler. Good shape. Core is 22" long and 2.25" thick. From end to end it is a total of 30" long. 2" inlet, 2.25" outlet. $150.
Stock 96+ GSR IM. Missing one or two little machine screws/bolts. $40.
Stock P30(I think its a GSR one) Flywheel. Needs to be resurfaced. $35.
Autometer Sportcomp Water Gauge. No sensor or bulb. $15.
USB-Serial converters. They can be used for datalogging off of modded ECUs. $15.
Stock GSR rear swaybar. It's in the honda box. $30.
Stock GSR radiator. Wrapped in the plastic. $50.
Modified by blufke at 2:34 PM 8/31/2008
blufke is offline
Old 05-03-2008, 10:13 PM
blufke's Avatar
Default Re: Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu,
Bump it up. Need to get this stuff out.
blufke is offline
Old 05-03-2008, 10:43 PM
424racer's Avatar
bump...
424racer is offline
Old 05-04-2008, 01:13 PM
blufke's Avatar
bump it up
blufke is offline
Old 05-04-2008, 05:24 PM
deason's Avatar
BUMP! FOR YOUR AZENIS ILL GIVE YOU $ 250 SINCE ILL HAVE TO DRIVE 2HRS ONE WAY! GAS PRISES SUCK
deason is offline
Old 05-04-2008, 05:32 PM
gsle3per03's Avatar
bump for some good stuff. just too dam far away!!
gsle3per03 is offline
Old 05-04-2008, 09:45 PM
blufke's Avatar
Default Re: (gsle3per03)
bump it up. some stuff going out the door soon.
blufke is offline
Old 05-05-2008, 08:36 PM
blufke's Avatar
Default Re: (blufke)
Traction bars sold. Someone is going to have less wheelhop.
blufke is offline
Old 05-06-2008, 07:50 PM
blufke's Avatar
Charge piping sold. Let's keep this stuff moving out of my garage. Everything is OBO.
blufke is offline
Old 05-08-2008, 02:11 AM
blufke's Avatar
up we go.
blufke is offline
Old 05-09-2008, 11:28 PM
blufke's Avatar
come on guys. lets hear some offers. bump it up.
blufke is offline
Old 05-10-2008, 08:35 AM
COLIMA0003ITR's Avatar
bump
COLIMA0003ITR is offline
Old 05-10-2008, 08:50 AM
vincentek9's Avatar
good stuff everywhere.
vincentek9 is offline
Old 05-10-2008, 01:18 PM
blufke's Avatar
Default Re: (vincentek9)
Traction Bars and Charge piping shipped out.
blufke is offline
Old 05-11-2008, 08:00 PM
blufke's Avatar
bump it up.
blufke is offline
Old 05-12-2008, 09:07 PM
blufke's Avatar
to the top.
blufke is offline
Old 05-13-2008, 10:40 PM
blufke's Avatar
lets keep this stuff moving.
blufke is offline
Old 05-14-2008, 09:53 PM
blufke's Avatar
DO IT!
blufke is offline
Old 05-16-2008, 07:05 PM
blufke's Avatar
to the top
blufke is offline
Old 05-16-2008, 07:18 PM
SOL Food's Avatar
PM'd.
SOL Food is offline
Old 05-16-2008, 07:45 PM
crazykamper's Avatar
bump for a local... might be gettin some business from me shortly...
crazykamper is offline
Old 05-17-2008, 10:22 AM
blufke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOL Food &raquo;</TD></TR><TR><TD CLASS="quote">PM'd. </TD></TR></TABLE>
PM'd back
blufke is offline
Old 05-17-2008, 11:45 AM
Turbo O's Avatar
whats your location?
Turbo O is offline
Old 05-17-2008, 01:21 PM
blufke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo O &raquo;</TD></TR><TR><TD CLASS="quote">whats your location?</TD></TR></TABLE>
Santa Barbara
blufke is offline
Old 05-17-2008, 09:06 PM
Hair Club President
pho dac biet's Avatar
BUMP for you
pho dac biet is offline
Quick Reply: Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu, Wid
