Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu, Wid
Hi,
Doing some long overdue garage cleanup. I am located in Santa Barbara CA, so pickup is always an option if you are local, and mandatory on some of the parts(ie Azenis). I'm always willing to discuss price within reason.
680CC injectors. They were cut to try and make them fit a stock honda rail. Too much material was cut away, and they need some more plastic on there to push the o-ring into the rail. I ran them this way for a while, but didn't have too much confidence in their ability to hold a reliable seal. But some effort and they wil be good reliable injectors. $125.
P72 Headgasket. Brand new. $75.
Sport Comp Pyrometer Gauge with wiring and sensor. I bought it used but never used it myself. $75.
Apex'i Fancy shmancy Dual Fannel(?) Filter. It has some light damage(pics). $50.
AEM Bypass Valve. Has a little dent in it, and a 1" slice in the foam that is not going to affect its performance unless you separate it by hand. which you won't do while you are driving . $20.
P28 ECU. Modded already(see pics). Only needs 2 $0.15 capacitors and one $0.50 chip(will go into DIP chip socket). You only need to solder in the capacitors. See here: http://www.superhonda.com/tech....html . $90.
Drag Intercooler. Good shape. Core is 22" long and 2.25" thick. From end to end it is a total of 30" long. 2" inlet, 2.25" outlet. $150.
Stock 96+ GSR IM. Missing one or two little machine screws/bolts. $40.
Stock P30(I think its a GSR one) Flywheel. Needs to be resurfaced. $35.
Autometer Sportcomp Water Gauge. No sensor or bulb. $15.
USB-Serial converters. They can be used for datalogging off of modded ECUs. $15.
Stock GSR rear swaybar. It's in the honda box. $30.
Stock GSR radiator. Wrapped in the plastic. $50.
Modified by blufke at 2:34 PM 8/31/2008
Re: Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu,
BUMP! FOR YOUR AZENIS ILL GIVE YOU $ 250 SINCE ILL HAVE TO DRIVE 2HRS ONE WAY! GAS PRISES SUCK
Charge piping sold. Let's keep this stuff moving out of my garage. Everything is OBO.
come on guys. lets hear some offers. bump it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOL Food »</TD></TR><TR><TD CLASS="quote">PM'd. </TD></TR></TABLE>
PM'd back
PM'd back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo O »</TD></TR><TR><TD CLASS="quote">whats your location?</TD></TR></TABLE>
Santa Barbara
Santa Barbara
