Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu, Wid
Hi,
Doing some long overdue garage cleanup. I am located in Santa Barbara CA, so pickup is always an option if you are local, and mandatory on some of the parts(ie Azenis). I'm always willing to discuss price within reason. 680CC injectors. They were cut to try and make them fit a stock honda rail. Too much material was cut away, and they need some more plastic on there to push the o-ring into the rail. I ran them this way for a while, but didn't have too much confidence in their ability to hold a reliable seal. But some effort and they wil be good reliable injectors. $125. https://lh3.ggpht.com/julius.rose/SB...8Medium%29.JPG https://lh5.ggpht.com/julius.rose/SB...8Medium%29.JPG P72 Headgasket. Brand new. $75. https://lh5.ggpht.com/julius.rose/SB...8Medium%29.JPG Sport Comp Pyrometer Gauge with wiring and sensor. I bought it used but never used it myself. $75. https://lh5.ggpht.com/julius.rose/SB...8Medium%29.JPG Apex'i Fancy shmancy Dual Fannel(?) Filter. It has some light damage(pics). $50. http://lh6.ggpht.com/julius.rose/SBu...8Medium%29.JPG https://lh4.ggpht.com/julius.rose/SB...8Medium%29.JPG AEM Bypass Valve. Has a little dent in it, and a 1" slice in the foam that is not going to affect its performance unless you separate it by hand. which you won't do while you are driving https://honda-tech.com/forums/images/smilies/embeer.gif . $20. https://lh3.ggpht.com/julius.rose/SB...8Medium%29.JPG P28 ECU. Modded already(see pics). Only needs 2 $0.15 capacitors and one $0.50 chip(will go into DIP chip socket). You only need to solder in the capacitors. See here: http://www.superhonda.com/tech....html . $90. https://lh5.ggpht.com/julius.rose/SB...8Medium%29.JPG Drag Intercooler. Good shape. Core is 22" long and 2.25" thick. From end to end it is a total of 30" long. 2" inlet, 2.25" outlet. $150. http://lh6.ggpht.com/julius.rose/SBu...8Medium%29.JPG Stock 96+ GSR IM. Missing one or two little machine screws/bolts. $40. https://lh5.ggpht.com/julius.rose/SB...8Medium%29.JPG Stock P30(I think its a GSR one) Flywheel. Needs to be resurfaced. $35. http://lh6.ggpht.com/julius.rose/SBu...8Medium%29.JPG Autometer Sportcomp Water Gauge. No sensor or bulb. $15. https://lh4.ggpht.com/julius.rose/SB...8Medium%29.JPG USB-Serial converters. They can be used for datalogging off of modded ECUs. $15. https://lh3.ggpht.com/julius.rose/SB...8Medium%29.JPG Stock GSR rear swaybar. It's in the honda box. $30. http://lh6.ggpht.com/julius.rose/SBu...8Medium%29.JPG Stock GSR radiator. Wrapped in the plastic. $50. https://lh3.ggpht.com/julius.rose/SB...8Medium%29.JPG Modified by blufke at 2:34 PM 8/31/2008 |
Re: Azenis, Traction Bars, Apex'i Filter, P72 Oil Pan with baffle, P72 Headgasket, P28 Ecu, P06 Ecu,
Bump it up. Need to get this stuff out.
bump...
bump it up
BUMP! FOR YOUR AZENIS ILL GIVE YOU $ 250 SINCE ILL HAVE TO DRIVE 2HRS ONE WAY! GAS PRISES SUCK http://is.rely.net/1-92-83128-l-OQ7p...WduI005zmA.gif
bump for some good stuff. just too dam far away!!
Re: (gsle3per03)
bump it up. some stuff going out the door soon.
Re: (blufke)
Traction bars sold. Someone is going to have less wheelhop.
Charge piping sold. Let's keep this stuff moving out of my garage. Everything is OBO.
up we go.
come on guys. lets hear some offers. bump it up.
bump
good stuff everywhere.
Re: (vincentek9)
Traction Bars and Charge piping shipped out.
Re: (blufke)
bump it up.
to the top.
lets keep this stuff moving.
DO IT!
to the top
PM'd.
bump for a local... might be gettin some business from me shortly...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOL Food »</TD></TR><TR><TD CLASS="quote">PM'd. </TD></TR></TABLE>
PM'd back |
whats your location?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo O »</TD></TR><TR><TD CLASS="quote">whats your location?</TD></TR></TABLE>
Santa Barbara |
