Southern California Fresno & Below
Looking for expert Honda mechanic near Burbank
Old 02-23-2011, 12:53 PM
LudeToAHatch's Avatar
Default Looking for expert Honda mechanic near Burbank
I'm looking for someone with extensive experience with Hondas. Specifically I need someone who can figure out why my 93 VX is doing the part throttle hesitation at operating temp (doesn't do it when cold).
The car has:
Correct timing
Recently adjusted valves
New plugs,
New OEM honda wires
New distributor/cap/rotor
New fuel filter
I originally thought it was the 02 sensor but I changed it out with no change in the hesitation. Next thing I thought was, it could be the EGR but I had a mechanic run some tests and he said the valves are opening and closing just fine so it's not that and that he thinks it could be "weak clutch springs" and I should just drive it at higher RPMs because it's a Honda and they're made to rev high :/ When i told him it's affecting my MPG as well and i'm losing 10mpg from 46-36mpg he says "Oh, well that car should be getting in the 30s no problem I don't know about it getting that high mileage." wtf??
So... I'm tired of dealing with dumb ****s excuse my french. I need a HONDA specialist. help plz!
Old 02-23-2011, 04:15 PM
KINGVEM^^ED6's Avatar
Default Re: Looking for expert Honda mechanic near Burbank
damn id fire that guy sucks gl bro
Old 02-23-2011, 04:17 PM
Clipsed's Avatar
You need to find someone who can graph the tps. I don't have the equipment to do it. But when the sensor gets hot it could he malfunctioning.
Old 02-23-2011, 05:01 PM
hmm I was thinking of replacing that but it seems like a bitch to remove
Old 02-23-2011, 05:17 PM
Clipsed's Avatar
Not really I've replaced them before. Pretty easy.
Old 02-23-2011, 05:30 PM
how'd you retract the screws?
Old 02-23-2011, 05:50 PM
Clipsed's Avatar
Make a slot to put a screwdriver in.
Old 02-23-2011, 06:02 PM
ah... ok so say I do that, get the new TPS in. What about adjusting it to the proper specs? I read somewhere on here that you have to do that.
Old 02-23-2011, 07:06 PM
Clipsed's Avatar
Yes you do. If its not adjusted the car will run funny and waste gas.
Old 03-04-2011, 12:03 PM
TTT... still need a mechanic. It's not the TPS, MAP or EGR valve :/
Old 03-09-2011, 02:04 PM
Clipsed's Avatar
Did you have the tps graphed or did you replace it?
Old 03-10-2011, 12:38 PM
it's not the TPS because it runs fine when the 02 isn't plugged in. I have a thread going on about this. it's not the 02 either.
Old 03-10-2011, 01:00 PM
Clipsed's Avatar
Maybe you need to check for shorted wires. weird issue you have
Old 03-10-2011, 02:20 PM
NooB
IT'S ME DAVID's Avatar
It's your iac idle air control it's on the manifold about $30 used on at junk yard call Honda heaven off penrose on the 5 freeway in valley.
Old 03-10-2011, 03:05 PM
Clipsed's Avatar
Lol iac valve would not cause his problem.
Hondaman56
09-08-2012 09:25 AM
jballerz23
10-06-2009 03:01 PM
djtech
40
07-10-2003 10:16 AM
djtech
01-29-2003 07:02 PM
djtech
01-29-2003 06:51 PM
Quick Reply: Looking for expert Honda mechanic near Burbank
