which is the biggest injectors i can run without a resistor box?
Old Sep 21, 2004 | 06:35 AM
Kelly.'s Avatar
I've quit using this account
Default which is the biggest injectors i can run without a resistor box?
i have a 94 civic.
turbo d16z6, p28 soon to be uberdata chipped.
my question is,
i thought 440 were the biggest?, but i had heard some one had 550 that i could use.
what is the max whp for 440's?
i plan on ordering them today, so any info would be great.
thanks
kelly
Old Sep 21, 2004 | 06:38 AM
igo4bmx's Avatar
i thought resistor boxes are required for a specific fuel injector type, not the actual size of the injector.
Modified by igo4bmx at 10:51 AM 9/21/2004
b18bturbo's Avatar
Default Re: which is the biggest injectors i can run without a resistor box? (llewsirc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 civic.
my question is,
thanks
kelly</TD></TR></TABLE>
the biggest injector that you can run withour resistor is the 780cc from RC they are costly at 299 a set but they are saturated and do work fine. Talk to ben@importparts.com if you need them he has plenty over there.
Old Sep 21, 2004 | 07:42 AM
Kelly.'s Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">i thought resistor boxes are required for a specific fuel injector type, not the actual size of the injector.
Modified by igo4bmx at 10:51 AM 9/21/2004</TD></TR></TABLE>
i thought they didnt make a injectors (which ever one you dont need a resistor box to run) above 440/550?
Old Sep 21, 2004 | 07:45 AM
Honda Hick's Avatar
Default Re: (llewsirc)
Nope, they have 750cc Saturated ones now (you only need a resistor box for Peak and hold injectors) - https://honda-tech.com/zerothread?id=918428
Old Sep 21, 2004 | 07:46 AM
SOHC_MShue's Avatar
you are thinking of the dsm 450cc and 440cc injectors. They are peak and hold injectors which require you to wire in a resistor box. Honestly I think wiring in the resistor box is definantely better than spending over $200 on rc injectors if you only need 440 or 450cc injectors. The resistor box really isn't hard to wire either.
Old Sep 21, 2004 | 08:30 AM
Kelly.'s Avatar
i just ordered saturated 550's,
i was told i wouldnt need a resistor box.
Old Sep 21, 2004 | 09:38 AM
Ben Huynh's Avatar
These are the largest saturated injectors currently available:
http://www.importparts.com/sho...=4480
http://www.importparts.com/sho...=4481
Also make sure you order some wire clips if you are OBD-2.
Old Sep 21, 2004 | 09:45 AM
Kelly.'s Avatar
thank you sir
Old Sep 21, 2004 | 11:38 AM
Turbowa's Avatar
Correct me if I'm wrong, but on the import parts web sit for the injectors it said 94+ accords. My 99" accord has high imp. injectors factory (13-15 ohms). The injectors you showed were low imp. wouldn't you have to use resistors or a resistor box for them to work correctly? By the way I"m getting ready to install 780cc percision injectors which are low imp. thanks
Old Sep 21, 2004 | 11:51 AM
Ben Huynh's Avatar
Default Re: (Turbowa)
Yea you will require a resistor box to run low resistance injectors in your 99 Accord. But the 650cc and 750cc injectors I listed are high resistance (saturated) injectors.
Old Sep 21, 2004 | 11:54 AM
Turbowa's Avatar
Default Re: (ben@importparts.com)
Thanks for clearing that up. Sorry I must have missed that part about them being high imp.
Old Sep 21, 2004 | 12:05 PM
Ben Huynh's Avatar
Old Sep 21, 2004 | 02:23 PM
ludetech
Guest
Posts: n/a
what exactly is a resistor box? I've seen them but what does it do and when do you need it?
Old Sep 22, 2004 | 04:18 PM
ludetech
Guest
Posts: n/a
Default Re: (ludetech)
any answers?
Old Sep 22, 2004 | 04:53 PM
DRAGLS's Avatar
So are their any advantages to running a peak&hold injector over a saturated type?
Also are the RC injectors disc,pintle,or ball&seat?
Hector
accord2civic2prelude
17
Feb 4, 2010 09:23 AM
CivSiClone_96
Dec 20, 2009 05:52 PM
Midori Green
May 19, 2007 05:45 AM
Flava
Sep 25, 2006 08:20 AM
LSEGHATCH
Oct 29, 2005 03:57 PM
