8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP!
Old Sep 20, 2004 | 03:18 AM
MarkAngelo's Avatar
Default 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP!
Hello there, I just finished my turbo setup, I am using an S-AFC, 450cc injectors and a T28 turbo boostin 8psi, with a pretty good sized spearco intercooler ofcourse.. anyways, Boost comes in at about 2,800rpm, and continues to build up till about 4 thousand full boost, The car is pulling hard from 2,800 to 4,000 and then the car bogs down and a/f gauge is LEAN LEAN! Do I need to raise the Fuel pressure or something?? is that why?? or what do you think is wrong?? I am using my stock fuel pressure regulator.. why is the car bogging down and the a/f gauge FULL LEAN!?? got my safc set to 35% accross the rpm range...
thanks,
Mark
Modified by MarkAngelo at 7:24 AM 9/20/2004
Modified by MarkAngelo at 7:25 AM 9/20/2004
Old Sep 20, 2004 | 04:44 AM
nsxmatt's Avatar
Default Re: 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP! (MarkAngelo)
What a/f did you use?
Old Sep 20, 2004 | 05:06 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP! (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">What a/f did you use? </TD></TR></TABLE>
I think he ment gauge ?
If you are going off a narrow band A/F gauge that uses you stock sensor or even one that come with a sensor like the greddy one than it is NOT going to help you TUNE your engine. You NEED a WIDEBAND
You also proly have a bad stock sensor
Old Sep 20, 2004 | 07:09 AM
SOHC_MShue's Avatar
its not gonna help...its just a lightshow.
Old Sep 20, 2004 | 07:30 AM
blundar's Avatar
Default Re: 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP! (SOHC_MShue)
yeah, but a christmas-tree guage running lean is blow-motor lean.
I'd try richening up your AFC a bunch. 5-8% maybe? That's what it's there for you know... The AFC hack isn't about a flat percentage as much as a flat AFR
Old Sep 20, 2004 | 07:35 AM
twkdCD595's Avatar
Default Re: 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP! (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">The AFC hack isn't about a flat percentage as much as a flat AFR</TD></TR></TABLE>
whole9
21
Jun 21, 2007 02:06 AM
J.nguyen
Aug 31, 2006 08:55 PM
MarkAngelo
Sep 23, 2004 05:51 AM
ninja8oi
Dec 14, 2003 05:10 PM
TURBO LS HATCH
Feb 19, 2003 11:43 AM
