crack in wastegate tube what would that cause
Old Sep 18, 2004 | 01:00 PM
ghettochild's Avatar
Default crack in wastegate elbow what would that cause
im running a revhard manifold and a 40mm hks W/G and on the elbow from the manifold to the W/G theres a small crack thats spreading what would this cause
anything noticeable sense theres a boost leak im just curious.
Old Sep 18, 2004 | 01:17 PM
Default Re: crack in wastegate elbow what would that cause (ghettochild)
Old Sep 18, 2004 | 01:32 PM
m R g S r's Avatar
Before the wastegate, it may cause you to over boost, if the exhaust gasses don't get to the wastegate, it will not open at the right time.
Not to mention that your wastegate may also fall off..
Old Sep 18, 2004 | 01:52 PM
Ri5e's Avatar
Default Re: crack in wastegate elbow what would that cause (m R g S r)
You should make a brace for the wastegate. My friend had the same problem with his wastegate breaking off (HKS WASTEGATE).
Old Sep 18, 2004 | 05:01 PM
DSF's Avatar
DSF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">it may cause you to over boost, if the exhaust gasses don't get to the wastegate, it will not open at the right time.
Umm, wouldn't it be the other way around. The turbo could suffer from slower spool times because of the exhaust leak. The wastegate opens by referencing boost pressure, not exhaust gas pressure.
Old Sep 18, 2004 | 08:38 PM
Default Re: crack in wastegate elbow what would that cause (DSF)
so that would be like what loss in power
Old Sep 19, 2004 | 03:14 AM
DSF's Avatar
DSF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettochild &raquo;</TD></TR><TR><TD CLASS="quote">so that would be like what loss in power </TD></TR></TABLE>
Possibly, or just slower spool up. It's according to the size of the crack.
Old Sep 19, 2004 | 03:32 PM
the cracks not that big but its spreading im welding it up tomm
Old Sep 19, 2004 | 03:40 PM
twkdCD595's Avatar
so then whats then general opinion here, I see one person saying it would cause over boosting and one saying otherwise?
obviously it should be fixed but curious what the resulting situation with building boost would be.
Old Sep 19, 2004 | 03:46 PM
DSF's Avatar
DSF
Default Re: crack in wastegate elbow what would that cause (twkdCD595)
I'm right, obviously
Think about it...the wastegate relieves exhaust pressure off of the turbine in order to control boost pressure by maintaining the compressor's speed. If there is a crack before the wastegate, then excess exhaust is being relieved and not being used to spin the turbine and in turn the compressor. Just imagine if the wastegate came completely off...I'm thinking that overboosting wouldn't be a problem there.
Old Sep 19, 2004 | 07:21 PM
sounds right to me
Nermin
Aug 3, 2011 09:22 PM
16vt
May 29, 2005 10:55 AM
specie
Feb 5, 2004 09:38 AM
MayhemSi
Sep 6, 2003 11:47 AM
whagkangmakulet
Oct 1, 2001 11:34 AM
