whats the maximum amount of boost if any that can be ran safely on stock injectors and uberdata?
Old Sep 18, 2004 | 08:43 AM
SOHC_MShue's Avatar
Default whats the maximum amount of boost if any that can be ran safely on stock injectors and uberdata?
My friend finally got his turbo setup up and running on his hatch. He is running uberdata and has some dsm blue tops that we were trying to put in his car. We have spend 2 days trying to get those damn 450's to work in his car, but we have had no luck. His car will start and idle fine, but whenever he got on the gas it would studder like it was missing or something. We thought we had the resistor box wired wrong so we rewired it over and over again. We even bought a continuity checker and a multimeter to make sure all the connections were fine. We also tried using the uberdata chip from my car which works flawlessly with my dsm 450's. Still it wouldn't work so we just threw the 240's back in and burned a map with the fuel values scaled back up. It runs perfect with the 240's. Its really smooth, but he hasn't gotten on the gas yet because were afraid to boost with those stock injectors. His wastegate spring is at 7psi. Do you think he will be safe only boosting at 7psi with the stock injectors until he can buy some rc 440's?
Old Sep 18, 2004 | 08:45 AM
mekkis's Avatar
Default Re: whats the maximum amount of boost if any that can be ran safely on stock injectors and uberdata?
160whp worth of psi.
Old Sep 18, 2004 | 08:46 AM
Finest's Avatar
I wouldn't try it.
If you're going to use the stock injectors, it's "safer" to run it with an FMU temporarily.
Old Sep 18, 2004 | 09:35 AM
SOHC_MShue's Avatar
well he does have an fmu and we tried that, but the car kept throwing codes even with a couple check valves. It runs great with uberdata though.
Old Sep 18, 2004 | 10:32 AM
EARLdaSQUIRREL's Avatar
official honda whore
take the 4 wires that you have going to the black and wire them up to the single red wire from the resistor box and then take those 4 wires and put them to the black ones and your problems will be solved
Old Sep 18, 2004 | 12:15 PM
menkio's Avatar
looking for an update, hope that works.
Old Sep 18, 2004 | 12:31 PM
adseguy's Avatar
are you using uberdata version 1.7? because I had huge problems running them correctly with my ls teg. I have a wideband and it would lean out and stuff. To fix that they said to open a GSR map and import the ls bin. Then disable vtec and change the rev limit lower. That and making sure you disable closed loop and everything worked fine for me. I thought too for the longest time it was the injectors. Check your plugs. If they all look the same then they all work the same meaning the injectors are fine. If your resistor box has a problem you probably would have already fried your ecu so that it not it.
IMO it's uberdata. Try different versions too. That could help. PM me if you want to talk about it. I spent hella time on this problem so I'm sure we can figure somethin out
Old Sep 18, 2004 | 02:20 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">take the 4 wires that you have going to the black and wire them up to the single red wire from the resistor box and then take those 4 wires and put them to the black ones and your problems will be solved </TD></TR></TABLE>
we have it wired up like that. The wiring is not the problem. We have checked it over and over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">are you using uberdata version 1.7? because I had huge problems running them correctly with my ls teg. I have a wideband and it would lean out and stuff. To fix that they said to open a GSR map and import the ls bin. Then disable vtec and change the rev limit lower. That and making sure you disable closed loop and everything worked fine for me. I thought too for the longest time it was the injectors. Check your plugs. If they all look the same then they all work the same meaning the injectors are fine. If your resistor box has a problem you probably would have already fried your ecu so that it not it.
IMO it's uberdata. Try different versions too. That could help. PM me if you want to talk about it. I spent hella time on this problem so I'm sure we can figure somethin out</TD></TR></TABLE>
also its not uberdata. Uberdata runs perfectly on his car with the fuel values scaled for 240cc injectors. I even tried taking the uberdata chip from my car and putting it in his car because my chip is setup for 450's. It still didn't work, and I know that chip is fine because it runs my car flawlessly. Oh and we also did end up blowing the ecu fuse at one point. We fixed that though.
Old Sep 18, 2004 | 02:30 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
240/10.5= 22.8pound injectors
22.8 X 4(#of cyclinder) X.85(duty cycle) /.5 = 155hp
about 6 to 8psi
Old Sep 18, 2004 | 04:26 PM
drvfast's Avatar
Don't do it.
Old Sep 18, 2004 | 04:33 PM
danl's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UJLSMoFo &raquo;</TD></TR><TR><TD CLASS="quote">240/10.5= 22.8pound injectors
about 6 to 8psi</TD></TR></TABLE>
Thats all fine and dandy but at higher rpm's the car doesen't have the time to inject the proper amount of fuel with the smaller injectors. Just build an uberdata basemap with a gsr with stock injectors. Set the fuel multiplier to 120%. Click on the duty cycle map in the uberdata editor and you'll see how ugly it really is!
EDIT:
At 5 psi and 7000rpm's I'm getting a duty cycle of 130%!!!!!!!! So basically you will run lean and blow your motor LOL.
Old Sep 18, 2004 | 05:46 PM
egizzle8
Guest
Posts: n/a
I'm boosting with 240's and a greddy bluebox on a homemade setup using a IHI RHB5 VF and hit .86 bar and never had any problems with bogging or stuttering, running lean or anything. I'm must have some super 240's or something?
Old Sep 18, 2004 | 05:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
we have it wired up like that. The wiring is not the problem. We have checked it over and over. </TD></TR></TABLE>
would you just try it, i swore up and down to phiz i had it wired right, but as soon as i switched it around it idled and ran perfect w/o any boggin, stuttering, or detonation up in the top end.......
so just switch em one time really quick
Old Sep 18, 2004 | 08:31 PM
SOHC_MShue's Avatar
yea I noticed how high the duty cycle is with the 240's. I told him I didn't trust it either. As far as the wiring goes we wired it just like ladysman said in his thread on it. We even tried wiring it like I did on my obd2 car which apparantely is different than obd1.
Old Sep 19, 2004 | 05:29 AM
danl's Avatar
Banned
Whats your fuel presssure under boost sucker. Were talking uberdata with stock FPR. If you can boost .86 bar on 240's and not go lean on an unmodified stock FPR then your car doesen't make **** for power.
Old Sep 19, 2004 | 05:47 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">Whats your fuel presssure under boost sucker. Were talking uberdata with stock FPR. If you can boost .86 bar on 240's and not go lean on an unmodified stock FPR then your car doesen't make **** for power.</TD></TR></TABLE>
He said hes runnign the greddy blue box..
Old Sep 19, 2004 | 07:59 AM
SOHC_MShue's Avatar
Modified by SOHC_MShue at 12:39 PM 9/19/2004
Old Sep 19, 2004 | 08:02 AM
SOHC_MShue's Avatar
now would it be possible to just throw an fmu in there with uberdata? I'm guessing i'd have to modify all the boost fuel tables to have the same values as the last column of vacuum so i wouldn't run too rich right? He tried using an fmu for a day or two until we tried putting in his new injectors and the car ran like ***. It kept throwing cel's and going into limp mode even with two check valves thrown in there. I know uberdata would be able to eliminate the check valve problem because I can give boost tables some values.
Old Sep 19, 2004 | 08:32 AM
TurboJesse
Guest
Posts: n/a
again...its not my car . We were just wondering about boosting on it temporarily until he can get some rc's.
haha when did we say that? The blue box sucks man We are using uberdata.</TD></TR></TABLE>
Danl wasn't reffering to you...read
Old Sep 19, 2004 | 08:38 AM
SOHC_MShue's Avatar
i'm stupid
Old Sep 19, 2004 | 09:26 AM
yusoslo's Avatar
bump cause Im the guy needing help.
Right now I am boosting 5-6psi but I havent pushed it past 5k rpms and 1/4 throttle and only once did I take it to 5grand normally its 4grand and light throttle.
also what if the injectors are not seated in the manifold all the way down, the sit out a bit from the seals but no leaks.
Old Sep 20, 2004 | 06:59 AM
SOHC_MShue's Avatar
bump
Old Sep 20, 2004 | 01:44 PM
yusoslo's Avatar
anyone else?
Old Sep 20, 2004 | 01:53 PM
mekkis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">now would it be possible to just throw an fmu in there with uberdata? I'm guessing i'd have to modify all the boost fuel tables to have the same values as the last column of vacuum so i wouldn't run too rich right? </TD></TR></TABLE>
Bingo, there's your quick fix until you get things sorted out. Keep fuel values static, use Uberdata to retard ignition, and everything's fine.
Old Sep 20, 2004 | 03:02 PM
yusoslo's Avatar
how much boost could I run then? and should I floor it, cause I have been boostin for 3 days and only giving it 1/4 throttle and shifting at 5k rpms
DrivinVtec
Jul 21, 2006 08:22 AM
98EK
Nov 29, 2004 10:47 PM
yusoslo
Sep 25, 2004 07:41 PM
Leb_CRX
May 24, 2003 10:17 PM
turbocivic22
May 11, 2003 04:39 PM
