Throwing CEL 21 and 22 still.
Old Sep 18, 2004 | 07:16 AM
spyderracing's Avatar
Default Throwing CEL 21 and 22 still.
Ok, maybe the last post was vague, but I'm still throwing CEL 21 and 22. I didn't have the wire to the vtec solenoid hooked up, so I figured it would stop throwing these codes when I hooked it up, but no. Anyone have any suggestions?
Old Sep 18, 2004 | 08:41 AM
Default Re: Throwing CEL 21 and 22 still. (spyderracing32)
errrrrrrr TTT
Old Sep 18, 2004 | 08:45 AM
Luserkid's Avatar
After you hooked up your VTEC wires did you restart your ecu (thats how youll get ried of the code)? If yes then take off the VTEC solenoid (sp?) and spray some carb cleaner in it and clean off the screen and try it again. If still nothing (and everythings wired up right) then you might need a new solenoid.
Old Sep 18, 2004 | 09:14 AM
Default Re: Throwing CEL 21 and 22 still. (Luserkid)
Well there was no screen in it.....
Reset ecu = pull ecu fuse in fuse box when car is off for 10 seconds?
Old Sep 18, 2004 | 09:38 AM
deSigi's Avatar
You need to pull the 7.5A radio backup fuse.
Old Sep 18, 2004 | 09:58 AM
Luserkid's Avatar
Default Re: (deSigi)
I just disconnect the Neg. Batt for 10 seconds when i restart my ecu.
Old Sep 18, 2004 | 10:03 AM
RotiEatter's Avatar
Ditto
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I just disconnect the Neg. Batt for 10 seconds when i restart my ecu.
Same, its pretty easy. 10mm socket and done.
Old Sep 18, 2004 | 11:12 AM
bpowa's Avatar
try swithing the wires i think you got the wires crossed.. like i did before... always reset the ecu
Old Sep 18, 2004 | 12:00 PM
Default Re: (bpowa)
Dude its 1 wire.....
Old Sep 18, 2004 | 12:24 PM
Default Re: (spyderracing32)
Ok I just reset the ecu, now im throwing code 22 only...
Old Sep 18, 2004 | 12:29 PM
Luserkid's Avatar
You have enough oil in the car right?
Old Sep 18, 2004 | 01:34 PM
Yea positive.
Old Sep 18, 2004 | 05:20 PM
TTVT
Oil level is just below the high dot.
Old Sep 19, 2004 | 11:07 AM
bpowa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyderracing32 &raquo;</TD></TR><TR><TD CLASS="quote">Dude its 1 wire.....</TD></TR></TABLE>
i'm sure it is 2.. solenoid is 1
https://honda-tech.com/zerothread?id=912138
one on a4 and one on d6 i believe
Old Sep 19, 2004 | 01:31 PM
Default Re: (bpowa)
I'm still throwing code 22..... 21 is gone. I replaced the solenoid from my d15b with the one from my VX, but it still throws 22. Do I need to swap out the lower half? Also, the lower half doesnt have a port for a plug like in some diagrams I've seen. Any ideas?
Old Sep 19, 2004 | 03:53 PM
UP UP UP
Old Sep 19, 2004 | 04:57 PM
Luserkid's Avatar
Whenever you do something are you resetting the ecu? Because you could have fixed it but not know because of that. Also if your going to swap VTEC Solenoids swap the whole thing, top and bottom.
Old Sep 19, 2004 | 05:01 PM
poison's Avatar
Grab a digital multimeter and do a continuity check on D6 and the Blu/Blk wire on the pressure switch.
make sure the thermostat ground is also properly connected.
Old Sep 19, 2004 | 08:21 PM
madturns's Avatar
I would try replacing the v-tec solenoid gasket. I think it is like $14 at Honda. Even if it does not solve the problem, although it did in my case, it is good to replace if you had the solenoid off a few times.
Old Sep 20, 2004 | 06:30 PM
Default Re: Throwing CEL 21 and 22 still. (madkurpt)
Ummm, you mean the o-ring right? Mine shouldn't be bad, I reapply it with hondabond every time.
mitchh29
11
Mar 24, 2013 09:08 PM
hatchhappy
Engine Management and Tuning
Sep 25, 2011 05:50 PM
WhiteDSM520
Jan 24, 2005 10:34 AM
CPR
Aug 21, 2003 09:04 AM
Stu
Sep 1, 2001 09:09 PM
