Reset ECU
Old Aug 31, 2001 | 11:48 PM
Stu's Avatar
Stu
New User
Default Reset ECU
How do I reset my ECU, or check engine light. Someone said that by unplugging the Vtec solenoid that I automatically tripped the CEL. So I figure if I just reset the ECU, and there isn't really a problem then the light will stay off. I have seen it on here before but I couldn't find it in search. TIA.
Old Sep 1, 2001 | 01:37 AM
LostGsr's Avatar
Default Re: Reset ECU (Stu)
If your CEL came on because you pulled the vtec solenoid, then you don't need to check the CEL code. Just pull the backup fuse for 2 minute and put it back in. Remember when you do this besure to have the radio code around if you still have the stock deck.
Old Sep 1, 2001 | 02:06 PM
ndustryalGSR's Avatar
You can reset the ECU by either pulling the ECU fuse or pulling the negative batery terminal. As mentioned above, be sure you have your radio code handy, as it will be reset, too.
Old Sep 1, 2001 | 09:09 PM
Stu's Avatar
Stu
New User
Default Re: Reset ECU (ndustryalGSR)
Thanks guys I really appreaciate it. I am going to go do it right now. I wan't to see if it will stay off before I go to highschool drags on monday.
WhiteDSM520
Jan 24, 2005 10:34 AM
HATCHFIEN
Nov 1, 2004 10:00 PM
racekar
Sep 21, 2004 04:42 PM
GeorgeY
Jun 29, 2003 08:59 AM
Bbasso
Jan 1, 2003 03:21 PM
