taking off my stock ls spoiler.....
Old Sep 17, 2004 | 11:20 AM
BANGBANG's Avatar
Default taking off my stock ls spoiler.....
how hard is it to take off the spoiler??? is it just those four nuts??? need help fast...thanx guys
Old Sep 17, 2004 | 11:27 AM
timmy8151's Avatar
Default Re: taking off my stock ls spoiler..... (BANGBANG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BANGBANG &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to take off the spoiler??? is it just those four nuts??? need help fast...thanx guys</TD></TR></TABLE>
Take off the four nuts and remove the wiring harness. If you don't care about the harness you can just cut it. But if you want to reuse it, then you just need to open up the panel on the hatch and unclip the harness.
Old Sep 17, 2004 | 11:30 AM
BANGBANG's Avatar
Default Re: taking off my stock ls spoiler..... (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
Take off the four nuts and remove the wiring harness. If you don't care about the harness you can just cut it. But if you want to reuse it, then you just need to open up the panel on the hatch and unclip the harness.</TD></TR></TABLE>
ru talking about the rear panel? and if u r, is it pretty easy to reach the harness??? sorry for the dumb questions..
Old Sep 17, 2004 | 04:24 PM
Cliffjumper2's Avatar
what are you going to use for filling the holes after the wing is removed? or do you even have to fill those holes? Since I believe the water that goes through those holes would not go inside.
Old Sep 17, 2004 | 04:35 PM
CleanLikeJdm's Avatar
Hype-R Stalker
The bolts and probably some wicked goo helping it stick well and seal.
And water won't go into the car but flow out the spot where the top of the tail-lights are.
You might want to either fill in the holes or atleast seal the egdes on them so they don't rust if they are actually unpainted.
Old Sep 17, 2004 | 06:06 PM
BANGBANG's Avatar
Default Re: taking off my stock ls spoiler..... (FlatBlackTeg)
thanx for all the replies. well i took it off couple hours ago and i used push pins from home depot to cover up those holes
Old Sep 17, 2004 | 06:07 PM
debogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BANGBANG &raquo;</TD></TR><TR><TD CLASS="quote">thanx for all the replies. well i took it off couple hours ago and i used push pins from home depot to cover up those holes </TD></TR></TABLE>
electrical tape IMO also looks very nice.
Old Sep 17, 2004 | 06:29 PM
hmmm, push pins. Are those found in hardware?
Old Sep 18, 2004 | 01:28 AM
debogsr's Avatar
Default Re: taking off my stock ls spoiler..... (DCcliffjumper2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCcliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm, push pins. Are those found in hardware?</TD></TR></TABLE>
I had the plastic caps before the electrical tape. I think thats what he means by push pins. you can get them for the size of the hole, and they do fit nice. The reason i didnt like them is because the paint would chip alot and they bubbled up where as i wanted somethin flush. I think there in the bolts/screws/nail section
Old Sep 18, 2004 | 07:44 AM
Default Re: taking off my stock ls spoiler..... (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">
I had the plastic caps before the electrical tape. I think thats what he means by push pins. you can get them for the size of the hole, and they do fit nice. The reason i didnt like them is because the paint would chip alot and they bubbled up where as i wanted somethin flush. I think there in the bolts/screws/nail section</TD></TR></TABLE>
ok, I understand what you mean, but how did you get the electrical tape to look better? I can't imagine electrical tape looking good at all.....got any pics?
Old Sep 18, 2004 | 09:58 AM
debogsr's Avatar
Sure heres some i just snapped outside. Im curious to what other people think...maybe its just me that likes the tape. haha, anyways this is also after about 5 months of driving and stuff and they still look pretty good.
Old Sep 18, 2004 | 09:00 PM
foolintherain617's Avatar
You could probably get those holes fiberglassed for under a $100 bucks and itd be painted to match. You wouldnt even know the car came with a spoiler.
Old Sep 18, 2004 | 09:11 PM
hammerdgolfer's Avatar
Default Re: taking off my stock ls spoiler..... (foolintherain617)
ya if you want to spray your hatch again you can shave the holes, i used jb weld for those, the "acura" sign holes and the keyhole caus some fagbag tried to open that **** with a screw driver or somethin
CHK4TIX
Feb 4, 2007 07:54 AM
INCNTRL4
Dec 23, 2006 01:32 PM
Relick!
Oct 31, 2004 01:41 AM
vietgsrboi
Mar 14, 2003 10:56 AM
EgSick
Jan 5, 2003 11:26 AM
