Rear Spoiler Remove ...
Old Jan 4, 2003 | 09:06 PM
EgSick's Avatar
Default Rear Spoiler Remove ...
perhaps you guys can help my friend out... he has a 98' LS and he gots the OEM Rear Spoiler on it.. what does he do to get it off.. well his only problem is the LED wires ..
does he cutt it? and do what?
thanks
Old Jan 4, 2003 | 10:34 PM
OneSloTeg's Avatar
Default Re: Rear Spoiler Remove ... (EgSick)
S
E
A
R
C
H
Old Jan 4, 2003 | 10:35 PM
neo1z's Avatar
Default Re: Rear Spoiler Remove ... (OneSloTeg)
yes you have to cut them
Old Jan 4, 2003 | 11:27 PM
IN VTEC's Avatar
Default Re: Rear Spoiler Remove ... (neo1z)
LOL! You dicks. I suppose you'll tell him to jump off a bridge next.
Rear spoiler removal:
.Work your fingers underneath the hatch interior panel on the passenger-side so you can disconnect the brake light harness.
.Pull it loose and disconnect the harness.
.Use a 10mm or 12mm deep socket and remove the (4) nuts along the outer edge of the hatch. These are the only nuts/bolts securing the spoiler to the hatch.
.Lift the spoiler up. It'll stick a little on the foam gaskets. Guide the harness out of the hole.
Old Jan 5, 2003 | 02:05 AM
IntEGNYC's Avatar
Default Re: Rear Spoiler Remove ... (IN VTEC)
wingless
Old Jan 5, 2003 | 02:19 AM
threatcon13's Avatar
New User
LOL! .Pull it loose and DISCONNECT the harness.
Old Jan 5, 2003 | 11:26 AM
J MaCk gSR's Avatar
Default Re: Rear Spoiler Remove ... (ALLMOTORDC2)
no you dont cut nothing!!!!!!!! you just need to pull the cord through the hole
Boostn B20
Aug 24, 2008 09:50 AM
Cuong-nutz
17
Dec 24, 2004 09:21 PM
tommyboy
Jan 28, 2003 07:41 PM
mickey513
Mar 11, 2002 03:21 PM
