1.6 head onto 1.5?
for the wiring you will need to get an ECU from a 92-95 1.6L sohc vtec (P28). not sure what you guys call them up there but that is from an 92-95 Si hatch or Ex down here. then there are 2 additional wires that need to be ran, one for vtec solenoid and one for oil pressure sensor. and also the oil pressure sensor will need a ground wire but that can go to the chassis anywhere , not all the way to the ecu. This head swap is called Mini-Me or Mini me. search either of those for alot of details.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">I dont know much about Canadian models but D-series can only go with D-series, and B-series can only go with B-series. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunn »</TD></TR><TR><TD CLASS="quote">both are d series, so im guessing they would fit. i just took my d series out and put in a b16a2. need to get rid of whats left
i dunno about canada but here in the states a 99 si has a B16a2 not a d16y8, theres no 1.5L that a b series head will fit on
</TD></TR></TABLE>i dunno about canada but here in the states a 99 si has a B16a2 not a d16y8, theres no 1.5L that a b series head will fit on
read these...
read this first...
Forum Rules and Guidelines.
https://honda-tech.com/zerothread?id=990205
then these...
Helpful FAQs thread.
https://honda-tech.com/zerothread?id=642479
D16Y7 / Y8 Mini-Me.
https://honda-tech.com/zerothread?id=735196
D15B7 / Z6 Mini-Me
https://honda-tech.com/zerothread?id=554053
search for mini-me, vtec wiring, or something that is just similar to your question.
now do some Searching
read this first...
then these...
D16Y7 / Y8 Mini-Me.
D15B7 / Z6 Mini-Me
