1.6 head onto 1.5?
i have a head off of a 99 civic si (cdn), d16y8 1.6 sohc vtec. will this fit onto a 1.5 out of a 94 civic? and how hard is it to wire in the vtec using the same ecu.
Re: 1.6 head onto 1.5? (Dunn)
I dont know much about Canadian models but D-series can only go with D-series, and B-series can only go with B-series.
Re: 1.6 head onto 1.5? (SkoundrelUSA)
both are d series, so im guessing they would fit. i just took my d series out and put in a b16a2. need to get rid of whats left https://honda-tech.com/forums/images...es/emsmile.gif
for the wiring you will need to get an ECU from a 92-95 1.6L sohc vtec (P28). not sure what you guys call them up there but that is from an 92-95 Si hatch or Ex down here. then there are 2 additional wires that need to be ran, one for vtec solenoid and one for oil pressure sensor. and also the oil pressure sensor will need a ground wire but that can go to the chassis anywhere , not all the way to the ecu. This head swap is called Mini-Me or Mini me. search either of those for alot of details. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: 1.6 head onto 1.5? (teal_dx)
ps. this swap will raise your compression anywhere from 10.5:1 to 11:1 depending on what headgasket you use. So if you're planning on boosting you might want to re-plan.
will an ecu off of a 99 work? altho you would have to go from obd1 to obd2b i beleive? thanks for the help.
no i dont think it will work. have to be the p28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">I dont know much about Canadian models but D-series can only go with D-series, and B-series can only go with B-series. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunn »</TD></TR><TR><TD CLASS="quote">both are d series, so im guessing they would fit. i just took my d series out and put in a b16a2. need to get rid of whats left https://honda-tech.com/forums/images...es/emsmile.gif</TD></TR></TABLE>
i dunno about canada but here in the states a 99 si has a B16a2 not a d16y8, theres no 1.5L that a b series head will fit on |
read these...
read this first... Forum Rules and Guidelines. https://honda-tech.com/zerothread?id=990205 then these... Helpful FAQs thread. https://honda-tech.com/zerothread?id=642479 D16Y7 / Y8 Mini-Me. https://honda-tech.com/zerothread?id=735196 D15B7 / Z6 Mini-Me https://honda-tech.com/zerothread?id=554053 search for mini-me, vtec wiring, or something that is just similar to your question. now do some Searching |
Search Mini-Me VTEC.
