installing motor mount inserts
Old Sep 11, 2004 | 08:20 AM
SFC's Avatar
SFC
Default installing motor mount inserts
So I've read several different threads and tutorials etc. etc. Some of them say to hold the engine up by the oil pan and some say this is horrible. I'm think that it should be ok to use the oil pan since two of the motor mounts will always be on at any given time. I guess my question is, when removing a motor mount, how should the engine be held up? Should I just put a jack under the oil pan or what?
*obviously I know you shouldn't do this when jacking up the car... but it seems there wouldn't really be that much weight on it if you were only pulling one motor mount at a time
Modified by SFC at 10:13 AM 9/11/2004
Old Sep 11, 2004 | 08:55 AM
mmuller's Avatar
Mad Scientist
Default Re: installing motor mount inserts (SFC)
if you got the inserts for the torque mounts, then you dont need to hold the engine; just take them off one by one.
if you need to take off the 2 main mounts make sure you put a block of wood in the middle of the jack/ oil pan
Old Sep 11, 2004 | 09:13 AM
SFC's Avatar
SFC
thanks
Old Sep 13, 2004 | 02:47 PM
SFC's Avatar
SFC
thanks
SilverWarrior
10
Apr 3, 2018 08:16 AM
rick-mp
Honda Fit
Oct 26, 2010 11:14 PM
fauxhawkid
Jan 29, 2006 02:59 PM
83Rabbit
Jun 16, 2005 08:01 AM
TypeRuz
Feb 19, 2004 07:58 PM
