Question about installing motor mount inserts....
Old Feb 19, 2004 | 12:19 PM
TypeRuz's Avatar
Default Question about installing motor mount inserts....
Hey y'all!
My Energy Suspension motor mount inserts just arrived today. It includes the lower middle and lower left/right inserts. I was planning on installing them myself, and I was hoping the instructions that come with it would be helpful.....but they proved to be very vague.
So, if anyone has any experience installing these, can you please give me some tips?
Do the mounts have to be removed to install the inserts?
or should i just jack the engine up a bit to relieve tension on the mounts?
Thanks!
PS- TO avoid excessive shake at idle, should i first install and try out the lower mid mount insert first? I think this is what was advised in previous posts.
Old Feb 19, 2004 | 01:13 PM
otb2000itr's Avatar
Default Re: Question about installing motor mount inserts.... (TypeRuz)
The ideal way to put them in is to relieve the tension on the mounts like they suggest...put a block of wood under the oil pan and jack up the oil pan....yeah you have to take the bolts out of the mounts to put the inserts in. The front two mounts are pretty easily gotten to, but the rear mount is a bitch. Takes a little while. Lastly, there really isnt any excessive rattle at idle, you will feel a bit more feedback through the steering wheel, the pedals, and the dash vibrates a bit when its cold but nothing huge. The elimination of wheelhop when dragging is well worth it imo....good luck!
Old Feb 19, 2004 | 03:43 PM
julow's Avatar
I did this about 2 weeks ago. It was a real PITA!!!
but here is a link that might help you out.
http://www.hazone.com/hmtrmount.htm
Old Feb 19, 2004 | 06:16 PM
mingchi69's Avatar
I to Smooch Pickle
the do their job of keeping the engine stiff.. but its gotten to a point that I have ordered new stock mounts to replace them. Can't stand the vibration.. makes your car feels cheap. but if you like racing, they will help, mostly only off the line. If you dont launch rarely ever, its not really worth it in my opinion. Anybody wants some lower tranny and AC mounts with the inserts. sell it real cheap.
Old Feb 19, 2004 | 07:58 PM
Black R's Avatar
25 Year Member
I replaced the rear ES inserts with Prothane ones recently (prothane = stiffer):
https://honda-tech.com/zerothread?id=680862
Pick up the prothane ones and do them first. THEN do the ES ones...
Luke G.
Mar 14, 2010 11:53 AM
CRXified
Dec 28, 2006 08:40 PM
Marlon88
May 8, 2005 03:40 PM
rocketfuelcerx
Jan 21, 2005 01:23 PM
Muckman
Aug 28, 2002 12:18 AM
