Oil return line
Old Sep 9, 2004 | 08:45 AM
StreetGlwLude's Avatar
Default Oil return line
Hey anyone know if you can run the oil return line from a turbo back into the valve cover? lets say back into the hole where the line is that runs from the intake into the valve cover?
Thanks
Old Sep 9, 2004 | 08:47 AM
PrecisionH23a's Avatar
Default Re: Oil return line (StreetGlwLude)
No. Unless your turbo sits about 3 inches above your valve cover, and I don't see that happening.
Gravity is the only thing that drains the oil from the turbo. So if you had the line going above the turbo, gravity is not going to allow the oil to travel upwards.
Old Sep 9, 2004 | 08:48 AM
Default Re: Oil return line (PrecisionH23a)
OK, thanks I didn't know that.
Old Sep 9, 2004 | 08:56 AM
is there any place you can run a return line to without drilling into the oil pan?
Old Sep 9, 2004 | 08:57 AM
Yep, drill into the block
Old Sep 9, 2004 | 09:02 AM
ok oil pan it is lol I really didn't want to drill anything.
Old Sep 9, 2004 | 09:06 AM
94vtecmn's Avatar
Not that it would apply here, but just offering up some additional info.
For the AmsOil by-pass oil filter system, you tap into the oil sending unit, with a T connector, run a line into the by-pass filter, and then you run a line from the filter to the Oil Fill Cap. Drill a hole in there, for return oil.
Old Sep 9, 2004 | 09:07 AM
eLUDEnu
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetGlwLude &raquo;</TD></TR><TR><TD CLASS="quote">ok oil pan it is lol I really didn't want to drill anything.</TD></TR></TABLE> You mean weld a fitting in?
Old Sep 9, 2004 | 09:11 AM
Default Re: Oil return line (eLUDEnu)
yeah I thought I'd have to drill into the block then get a fitting welded in that's what your saying right?
gabe768
May 22, 2010 01:18 PM
wunest
Apr 8, 2010 10:12 AM
Gtimportfanatic
Oct 31, 2007 09:06 PM
2LiterTurboSeR
Feb 27, 2006 02:38 PM
alfee
Jun 28, 2004 04:10 PM
