Oil cooling
Oil cooling
Can anyone give me a detailed explaination on how to run the oil lines for the turbo cooling? i am about to begin my project soon and thats one part im confused on
Re: Oil cooling (Gtimportfanatic)
Most honda motors have a sensor on the back of the block right by the oil filter. you need to get some sort of an adaptor (usually a T fitting) to tap the oil line into that and run the oil line from that to the turbo. This is your oil feed line. You will also want to drill a hole in the front of the oil pan and weld some sort of bung to that then run your line to the turbo. This is your oil return line. For more detailed intstuctions, you might want to ask your question in the FI forums. SEARCH is your friend
killamike0001
09-06-2007 12:22 PM
