Is my Timing off
Old Sep 8, 2004 | 08:47 PM
Cractos's Avatar
Default Is my Timing off
This is a lsvtec with a LS timing belt and water pump...Is my timing off??????
Old Sep 8, 2004 | 10:36 PM
notstock93's Avatar
Default Re: Is my Timing off (Cractos)
Looks like it, yea
Old Sep 8, 2004 | 10:57 PM
92bubblesi's Avatar
Yea it looks like your intake cam is off a tooth.
Old Sep 9, 2004 | 01:02 AM
B18OnTop's Avatar
Default Re: Is my Timing off (92bubblesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92bubblesi &raquo;</TD></TR><TR><TD CLASS="quote">Yea it looks like your intake cam is off a tooth.</TD></TR></TABLE>
yep. move it one tooth and your good.
-Aaron
Old Sep 9, 2004 | 02:53 AM
JDMorgan's Avatar
thats the funniest thing i heard in a while man. how do u even know the motors at tdc? also i hope you got a vtec oil pump in that beast.
Old Sep 9, 2004 | 06:44 AM
JimBlake's Avatar
Default Re: Is my Timing off (KraZEtEggIE)
Looks to me like the camera was shaking when you took the picture...
I can't see the little dimples out at the sprocket teeth. The 'up' arrows are only approximate, those dimples are the REAL timing marks. Besides, I can't see the crankshaft pulley either.
Old Sep 9, 2004 | 11:25 AM
Sack Master's Avatar
Default Re: Is my Timing off (JimBlake)
Providing your crank is 100% at TDC then yeah your timing is off.
Old Sep 9, 2004 | 12:51 PM
TeamCracka's Avatar
Default Re: Is my Timing off (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Providing your crank is 100% at TDC then yeah your timing is off.</TD></TR></TABLE>
Regardless of the position of the crank, its clear those gears arent aligned!!!
Old Sep 9, 2004 | 02:03 PM
Cractos's Avatar
THANKS EVERYONE
Old Sep 9, 2004 | 02:12 PM
Cractos's Avatar
WOULD THIS MAKE MY CAR NOT START?
Old Sep 9, 2004 | 02:17 PM
mmuller's Avatar
Mad Scientist
Default Re: (Cractos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cractos &raquo;</TD></TR><TR><TD CLASS="quote">WOULD THIS MAKE MY CAR NOT START?</TD></TR></TABLE>
it could, but usually it will just make it run like ****
Old Sep 9, 2004 | 06:26 PM
92bubblesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">thats the funniest thing i heard in a while man. how do u even know the motors at tdc? also i hope you got a vtec oil pump in that beast.</TD></TR></TABLE>
I assumed the crank was at TDC. If thats the funiest thing you have heard in a while I would hate to spend a day in your shoes.
Old Sep 10, 2004 | 02:59 AM
1993sir05's Avatar
yes
Old Sep 10, 2004 | 03:44 AM
TeamCracka's Avatar
Very much so.
Honda motors are refered to as "interference" engines, meaning if something like timing is thrown off, moving parts WILL collide. You're lucky you didnt bend any valves, I lucked out the same way and there seems to be about a 50% chance of fuckn **** up when having a timing belt slip.... but yeah having them off that much WILL cause low compression, failed startup, and a for-sure-not-running-car.
Old Sep 10, 2004 | 06:41 AM
mmuller's Avatar
Mad Scientist
Default Re: (TeamCracka)
one tooth off wont make the pistons contanct the valves....unless of course he has some very big pistons.
Old Sep 10, 2004 | 06:12 PM
Cractos's Avatar
my starts now...thanks everyone...for the info....
Old Sep 12, 2004 | 07:30 PM
Cractos's Avatar
Now that it starts it is leaking oil....I THink it is coming out of the HG.....and the LSVTEC line....on the good side is that it is fast....well faster then my ep3.....I need some info on what to do about the leaks
Old Sep 13, 2004 | 03:58 PM
Cractos's Avatar
BUMP
Old Sep 13, 2004 | 06:12 PM
Dan GSR's Avatar
is it a lot of oil?
did you plug the head for the stock oil passage
maybe have your headgasket upside down?
tapboyzlilj
Feb 5, 2008 11:50 AM
boosted ek
11
Feb 12, 2005 06:55 PM
DC2*Integra
Oct 13, 2004 02:50 PM
bb6h22
Oct 11, 2004 10:28 PM
lsvtec101
Apr 27, 2004 09:45 PM
