has anybody done the 5th gear swap in a Y1
Old Sep 8, 2004 | 02:22 PM
coot_er's Avatar
Default has anybody done the 5th gear swap in a Y1
i do a lot of 60 mph traveling and want to swap in the ls 5th so my rpms will go down just enough to get out of that 3100 rpm loud range. has anyone done this on a Y1? were are your RPMs at 60 abd 70 ,ph? i have seen the right up on how to do it, i just want to hear from someone who has done it on a Y1.
thanks.
Old Sep 8, 2004 | 03:59 PM
coot_er's Avatar
Default Re: has anybody done the 5th gear swap in a Y1 (coot_er)
nobody has done this?
Old Sep 8, 2004 | 04:52 PM
rsbad454's Avatar
i thought the y1 had something similar to LS 5th?
Old Sep 8, 2004 | 06:56 PM
coot_er's Avatar
Default Re: has anybody done the 5th gear swap in a Y1 (rsbad454)
Y1 has .870 Ls is .742
Old Sep 8, 2004 | 07:12 PM
sinfultrends's Avatar
im at 4000 at 60.. whatabiatch
Old Sep 8, 2004 | 07:33 PM
coot_er's Avatar
Default Re: has anybody done the 5th gear swap in a Y1 (sinfultrends)
sounds like you need to do a Ls swap your self
Old Sep 8, 2004 | 08:19 PM
daidilus's Avatar
ummi think your tach is severly off!!!!!when i crushing at 80....my Y1 tranny(has a sticker that says Y1 on it) 3800-4000
at 1st thats what i was thinking,
but i don't drive HWY that much, and these motors are rev happy anyways.. so cruzzin' at 5K RPM isnt that big a deal..
gas is a bitch though...
catch osama!
Old Sep 8, 2004 | 09:08 PM
SqueezinEF's Avatar
Default Re: has anybody done the 5th gear swap in a Y1 (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">ummi think your tach is severly off!!!!!when i crushing at 80....my Y1 tranny(has a sticker that says Y1 on it) 3800-4000</TD></TR></TABLE>
You must have the USDM Y1, which I believe is from 93 LS. He has the JDM Y1, which revs at around 5K at 80 mph. I have the JDM J1 from the Xsi and I rev at 4400K at 75 mph.
Old Sep 8, 2004 | 09:44 PM
b16_madman's Avatar
Default Re: has anybody done the 5th gear swap in a Y1 (SqueezinEF)
i've done it....search for my threads created and you'll have a great how to that will guide the way for a j1 tranny at least, should be similiar
Old Sep 9, 2004 | 04:38 AM
daidilus's Avatar
ummm no...i used to own a teg with a USDM Y1......ummm and uhhh.....this tranny has much shorters gears....do me a favor run it to 8000 how fast are you going in 1st?? i am going 40
well i may have been wrong.....at 70, i am going 4000. and then vtec kicks at 90 in 5th..... i love not having to downshift to pass someone...
Old Sep 9, 2004 | 05:56 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SqueezinEF &raquo;</TD></TR><TR><TD CLASS="quote">USDM Y1</TD></TR></TABLE>
No such thing.
Old Sep 9, 2004 | 06:26 AM
rioninja's Avatar
I have done this. Its incredibly easy, since 5th gear is on the end of the gearshafts.
The only thing special you need is a 32mm socket, which you probably already have
if you have changed axles before.
Old Sep 9, 2004 | 06:30 AM
Gearspeed-Performance's Avatar
Default Re: has anybody done the 5th gear swap in a Y1 (Targa250R)
Sorry guy Y-1 are Jap spec unless you mean YS-1. My JDM YS-1 with Type R 4.78 final drive runs at 4800 at 80mph.
Old Sep 9, 2004 | 06:40 AM
HamiltonRex's Avatar
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">ummm no...i used to own a teg with a USDM Y1......ummm and uhhh.....this tranny has much shorters gears....do me a favor run it to 8000 how fast are you going in 1st?? i am going 40
well i may have been wrong.....at 70, i am going 4000. and then vtec kicks at 90 in 5th..... i love not having to downshift to pass someone...</TD></TR></TABLE>
Okay lets get some info straight here. USDM Y1 DOES NOT Exist. So NO you did not own a teg with a USDM Y1..
As far as MPH and RPM check here http://crx.honda-perf.org/math/index.html
The accuracy seems to be out, because i run on 14" tires, and at 60mph im just below 4k. This says 3535rpm. So maybe my tach is off 300rpm? Wouldnt doubt it.
-Eric
Old Sep 9, 2004 | 06:48 AM
crx_88_si's Avatar
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
check your tire pressure
Old Sep 9, 2004 | 07:10 AM
daidilus's Avatar
my bad i meant YS1....
FeelTheBass
14
Mar 28, 2014 07:44 AM
munkyx8344
Transmission & Drivetrain
Dec 21, 2011 09:33 AM
biggdogg
13
Jan 15, 2005 05:08 PM
MCoupster
Jun 9, 2004 07:17 PM
JDMpianoguy
Dec 15, 2003 11:20 AM
