Turbo Horsepower Question
Old Dec 6, 2001 | 01:24 PM
GruvyTune's Avatar
New User
Default Turbo Horsepower Question
Ok, I got my Fmax/Hondata up and running well now. No oil leaks; I don't think any significant exhaust leaks.
I have it dyno tuned to at least 8psi and have fuel and timing mapped to about 10psi before its gonna cut fuel since we aborted further tuning when I sprang the turbo oil leak last month.
I'm getting great boost which hold steady and I'm wanting to get back to a dyno to continue fine tuning.
I'm wondering if I'm getting all the horsepower I should be. Should my tires be busting loose from the road at 8psi in a GSR if everything is ok? I'm getting great pull but not the kind of traction losing pull I was hoping for. Maybe at 8psi I shouldn't expect that?
tf
Old Dec 6, 2001 | 01:42 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Turbo Horsepower Question (GruvyTune)
I would think at 8 PSI you should break em loose, I Remember some people saying they were breaking loose at 6PSI.
Old Dec 6, 2001 | 06:03 PM
GruvyTune's Avatar
New User
Default Re: Turbo Horsepower Question (ForcedAccord)
Maybe i'm just not tuned right then?
Old Dec 6, 2001 | 10:39 PM
dustin's Avatar
Define "breaking them loose". Wheel spin after launching... from a roll? Entire loss of traction or just squeeling?
Dustin
Old Dec 7, 2001 | 03:16 AM
GruvyTune's Avatar
New User
Default Re: Turbo Horsepower Question (dustin)
any loss of traction especially once rolling and turbo engages at WOT
Old Dec 7, 2001 | 03:34 AM
Liltrix's Avatar
What tires are U using? Are they really sticky?
Old Dec 7, 2001 | 05:14 AM
Ubermensch's Avatar
If you've dyno tuned it then you've got the torque and hp figures. So how much power are you making? That would be a lot easier to compare to know if you're tuned well than something subjective like whether you break the tires loose.
Old Dec 7, 2001 | 06:51 AM
GruvyTune's Avatar
New User
Default Re: Turbo Horsepower Question (Ubermensch)
i was getting about 210HP at 8psi but i am sure its more now.
at 6psi it was about 200HP
the turbo was not working well then and was leaking oil and had play in the shaft.
i will try to dyno again soon and retune to at least 10-12psi when i do. My steering is hard to control once i hit high boost and get into vtec (set at 5800 now).
tires are coopers i think in the fronts right now. a bit sticky but not very
Old Dec 7, 2001 | 07:31 AM
Phantom's Avatar
Why is your vtec point so high?
Old Dec 7, 2001 | 12:03 PM
GruvyTune's Avatar
New User
Default Re: Turbo Horsepower Question (Phantom)
when set at stock there was a huge power dip at the vtec crossover (4800RPM). That was fixed by raising it to 5800 so now the power curve is straight without the dip.
h22accordian
Nov 4, 2011 03:36 AM
Bizzle5OH3
Jul 14, 2011 11:01 AM
neoc03
Dec 6, 2007 12:41 PM
.RTErnie
Jul 17, 2005 08:45 PM
Fired Honda
Jul 17, 2003 09:17 AM
