do you think it will last?
Old Sep 3, 2004 | 09:33 AM
PFSeg's Avatar
Default do you think it will last?
i'm about to swap in a b18a1 and tranny out of a 90 Integra RS. the motor has 187489 miles on it. i'm going to be drag racing it and was wondering if you guys thought that a stock motor with mileage that high would last under the abuse of drag racing. i do plan on getting a new water pump, timing belt, and clutch before the swap. does anyone recomenned doing anything else. i've heard that you should do something called a compression test. is this true?
Old Sep 3, 2004 | 12:21 PM
PFSeg's Avatar
Default Re: do you think it will last? (sleepercrx90)
bump
Old Sep 3, 2004 | 03:04 PM
8200RPM's Avatar
local hippie
Common sense will tell you any motor with that many miles is prone to have issues with any component... Things break/malfunction from wear and tear all the time... Just keep up with maintenance jobs and it might help prolong its life.
My d16y8 has 180k+ miles... several diff things have stopped working. To say if your motor is going to last is unpredictable.
Old Sep 4, 2004 | 02:45 AM
drussell4801's Avatar
I wouldn't even count on this motor lasting another 20K under normal driving conditions.
Go for a lower mileage engine.
Evolution-93-Ex
Mar 20, 2006 12:31 PM
Chunty Butt Kevin
Mar 23, 2005 09:36 PM
civicguy_wi
Feb 27, 2004 06:18 PM
Hatchd
17
Jun 9, 2003 01:58 PM
Pengo
May 12, 2002 11:24 AM
