How many miles?
Old May 12, 2002 | 08:48 AM
Pengo's Avatar
Default How many miles?
i kno there are alotta pple out there with higher mileage motors that still run turbo, and i was just wondering if there's any minimum or maximum amt of miles by which i should decide whether to turbo an engine or not. i have 81K rite now, if compression and everything looks fine, should it be ok to turb with low boost (5-8 psi)? my tranny went out and i have a new one along with a new clutch coming in and i think if my motor can handle it, i'm ready to start boostin. thanks
Old May 12, 2002 | 09:01 AM
92JDMSiR's Avatar
Default Re: How many miles? (Pengo)
if your compression numbers look good, and there is nothing majorly wrong(like a huge oil leak) then go ahead.
Old May 12, 2002 | 10:09 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: How many miles? (92JDMSiR)
I turboed my LS at 115K miles. My motor crapped out at 118K miles due to my own fault though. You should be fine if your motor numbers look good.
Old May 12, 2002 | 11:24 AM
Jared's Avatar
With high mileage engines its all about maitenance. Get it, do a timing belt, replace plugs, wires, rotor, and cap, anything thats leaking, fuel filter, and do an oil change. and make sure you have good compression and leakdown numbers. Sometimes mileage doesnt tell the whole story of an engine in terms of wear and power. its all about maitenance.
Chunty Butt Kevin
Mar 23, 2005 09:36 PM
Garbonzon311
Jan 26, 2004 10:54 PM
slow hatch
Feb 22, 2003 08:02 PM
See Are X
Sep 19, 2002 01:07 PM
b18tdelsol
Apr 17, 2002 10:34 PM
