Tranny Gurus' - Need some Ideas/Help
Old Sep 1, 2004 | 11:27 AM
sohc hatch's Avatar
Default Tranny Gurus' - Need some Ideas/Help
Alright, I have a d15b inside a 90 hatch. I have a dx tranny (soon to be si) with a 91 act heavy duty pressure plate, 6 puck disc and 91 act prolite flywheel. My question is the following:
I have a noise coming from the tranny - when I push the clutch pedal down the noise stops. It's like a clattering - clak clak clak and it comes and goes. Mostly comes and stays, lol ! It goes up and down on pitch also like if I had a symphany in my tranny. I have no idea what it can be ? Pilot bearing, Throw-Out bearing, spring, xcetera ? Anyone with an idea your info will be of use. I've been driving the car like these for a while since I have plans on changing the tranny real soon - but of course I would like to learn what the problem is and possibly fix it for future refernce. Let me know.
Good Day,
RH.
Old Sep 1, 2004 | 11:59 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Tranny Gurus' - Need some Ideas/Help (egturbohatchback)
Sounds like a spring in your clutch worked it's way out.
A bearing would normally whines for a while before it dies in a messy explosion of chunks and bits.
Old Sep 1, 2004 | 02:48 PM
sohc hatch's Avatar
Default Re: Tranny Gurus' - Need some Ideas/Help (4drEF)
Thanks 4dr for a timely response - those were one of my ideas. I plan on putting in an SI tranny and hitting the track finally so it doesn't bother me to much but it can get a little annoying.
Can that cause any DMG to my clutch system ? J/W since as you can tell it's not a regular street disc and oem fly - it was a dent in the pocket but hey you want something to go for it.
Good Day,
RH.
Old Sep 1, 2004 | 03:20 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbohatchback &raquo;</TD></TR><TR><TD CLASS="quote">
Yes... if that's what it is.
I have read quite a few stories of the ACT springs popping out.
Old Sep 1, 2004 | 03:28 PM
Targa250R's Avatar
be professional
Most likely the input shaft bearing - this is a common problem on high-mileage D-series engines, particularly ones that have been abused and have been used with overly-aggressive aftermarket clutches.
If it has been making this noise (a "chattering" noise heard with the clutch out in neutral, which goes away when you push in the clutch) for a while, and gotten progressively louder, it is getting ready to blow, at which time it will destroy your transmission case.
If a spring had popped out of your clutch, you probably wouldn't be able to drive the car. Usually when that happens, the clutch stops working.
sohc hatch's Avatar
If I wanted to replace them with the new tranny - what do you recommend ? OEM ? The tranny I currently have I bought used from someone locally expecting it to be an SI tranny and it was a DX tranny with a grinding 3rd gear.
Also, my first gear sometimes doesn't catch when I put it in (regular driving). Would this be happening due to the current problem at hand ?
Good Day,
RH.
Old Sep 1, 2004 | 08:33 PM
davens's Avatar
Well, how much do you want to spend on a new tranny?
Just about anything you pick up used these days is going to be 15 years old with at least 150k on it...most likely needing some kind of freshening up.
Old Sep 1, 2004 | 08:42 PM
BauleyCivic's Avatar
Risky Business
Default Re: Tranny Gurus' - Need some Ideas/Help (davens)
Input shaft bearings are fun!
Old Sep 2, 2004 | 09:20 AM
sohc hatch's Avatar
Default Re: Tranny Gurus' - Need some Ideas/Help (BauleyCivic)
Thanks everyone for the extra replies.
Daven - You know EFFIN Motorsports personally? - You have bought from them ? - Let me know your experiences - That tranny deal looks good ?
Good Day,
RH.
Old Sep 2, 2004 | 09:22 AM
EFSiR's Avatar
main shaft bearing, amen...
Old Sep 2, 2004 | 10:41 AM
crx_88_si's Avatar
sounds like a throwout bearing to me too!
Old Sep 2, 2004 | 06:57 PM
nuc79's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a throwout bearing to me too!</TD></TR></TABLE>
input shaft bearing. throwout bearing would do the opposite (noise with clutch pressed in).
my DX tranny had the same symptoms. I was just going to replace the bearing, but upon taking it apart, ISB (aka mainshaft case bearing) came apart in 4 pieces, all the ***** fell out too. Mainshaft had a deep ring gouged into it, rendering it unusable.
Bearing was so far gone that the shaft was wobbling and would throw the tranny from 2nd and 5th into Neutral.
Always grab the input shaft of a tranny and check for side-to-side play/slop before buying it. If there's noticable play, it will most likely have the sound you described. FYI, that type of bearing failure is usually caused by low oil sometime in the tranny's life, as it's the highest positioned bearing, and the one with the most load on it
Old Sep 2, 2004 | 07:04 PM
Loaded Butane's Avatar
Good Day,
RH.</TD></TR></TABLE>
AFAIK Davens is one of the owners of Effin Motorsports. He's been around a while and is a good guy.
nanagsr
Mar 30, 2009 10:26 AM
onetrueshyguy
May 6, 2005 09:48 AM
Jeffro_93
12
Oct 10, 2003 03:08 PM
BoostedsiR
May 31, 2003 05:28 PM
Ass_Clown
Sep 22, 2002 08:34 PM
