tranny problem?
tranny problem?
I hear I noise it sounds like something is spinning roughly inside my tranny I think it could be the throw out\ release bearing and or pilot bearing, I got a clutch masters stage 3 clutch and pressure plate where can I get this how much do they cost, can it be a generic bearing, Pulling tranny's suck. when I push the clutch in most of the noise goes away and it makes a slight noes could that be my differential? My axles are brand new. Im just trying to give you guys a better possability for a better diagnosis.
Thanks
Thanks
Re: tranny problem? (BoostedsiR)
Chances are it is your throwout bearing. My tranny was doing the same thing. Was it replaced when you last replaced your clutch? I just had mine swapped out and the noise went away....but now its making a noise when the clutch is not engaged..arg! good luck w/ the tranny! Rick
JDM SLICK
02-15-2005 11:17 PM
