AFC setting's tuned for turbo. wanna convert back 2 na but how??
Old Aug 30, 2004 | 09:44 PM
2SlowDC's Avatar
Default AFC setting's tuned for turbo. wanna convert back 2 na but how??
Well the turbos off and put everything back 2 stock except teh fuel rail and the fpr. I want to keep the afc in because last time I tried to disconnect it it ran like ****. how do I set the afc to stock settings? do i just set everything back to zero?
Old Aug 30, 2004 | 09:52 PM
Ramocheese's Avatar
Default Re: AFC setting's tuned for turbo. wanna convert back 2 na but how?? (lsVtec...)
If you're running a stock FPR and stock injectors, all you need to do is zero everything out and it'll run off the stock ECU without adjusting any of the sensor values to the ECU.
Old Aug 30, 2004 | 09:54 PM
2SlowDC's Avatar
Default Re: AFC setting's tuned for turbo. wanna convert back 2 na but how?? (Ramocheese)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ramocheese &raquo;</TD></TR><TR><TD CLASS="quote">If you're running a stock FPR and stock injectors, all you need to do is zero everything out and it'll run off the stock ECU without adjusting any of the sensor values to the ECU.</TD></TR></TABLE>
are u sure about this? can anyone back this up. as far as timing goes and all that, the afc automatically adjusts it right?
should i put my stock fpr back on?
Old Aug 30, 2004 | 10:28 PM
Ramocheese's Avatar
You'll need to, or at least make sure your aftermarket FPR is set to the same fuel pressure as stock, otherwise your car will run overall richer or leaner depending on which way you have the fuel pressure set.
The AFC doesn't do anything with timing, that is all set by the ECU. All the AFC does is take the air sensor reading and changes it, so the ECU thinks there is less/more air entering the engine than there really is, so the ECU runs less/more fuel than it would normally.
Old Aug 31, 2004 | 11:45 AM
2SlowDC's Avatar
Rip Rawr
Nov 17, 2011 03:44 AM
OrangeBoost
Feb 1, 2006 11:02 AM
Ramocheese
May 7, 2002 10:21 PM
Ramocheese
May 7, 2002 08:59 PM
