How much work is it and is it worth it to take out my A/C?
Old Dec 5, 2001 | 05:16 AM
JM Performance's Avatar
Default How much work is it and is it worth it to take out my A/C?
Whats your guys take on removing my A/C?
First of all I never (once or twice in the summer) use it. The benefits are:
Weight savings? 50lbs or so? it'll help compensate for the near 100 I'm adding w/ the turbo.
Increased cooling....no compressor blocking my radiator. (main reason)
Increased power? Although I'm pretty sure that its extremely minimal.
how long does it take? Also, isn't there some shroud I need to buy to keep my vents working? so....is it worth it?
Old Dec 5, 2001 | 05:25 AM
rtype11's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (00SilverLS)
all you need to buy is the "tunnel" from a non A/c equipped Integra, it goes under the dash between the heater and blower, you will be removing your evaporator. Then you need a big oval grommet plug to cover the hole in the firewalll right behind the battery. If you do not plan on reselling any of the AC stuff, it will only take a couple hours to remove - cutting all lines make em come out faster.
Just go to a shop that can drain your system before you begin. you get a lot more air to the rad as the condensor will be removed. remember to either remove the fan on the driver side or hook it up to same relay as rad fan.
Old Dec 5, 2001 | 05:32 AM
Canuk_SiR's Avatar
I took out my AC this past summer. It took about 2 hrs, but that was mostly spent trying to free those bolts that hold the AC bracket to the block. The total weight savings is probably about 60 lbs. I don't know about a shroud or anything for the vents. I didn't remove the part that's between the firewall. I just disconnected the 2 hard lines that connect to the firewall, and used some duct tape to plug it up You don't really get a power improvement, because the compressor doesen't use any power when it's not on.
I have heard from someone that their cooling fan stopped working when they removed their AC system. I haven't had a problem like this, but I only removed the AC hardware, and left the fuses and electronic stuff like the connectors. I don't know exactly if the AC system is tied in with the cooling system, but just keep this in mind
Old Dec 5, 2001 | 06:18 AM
b18b98's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (Canuk_SiR)
if you don't use the A/C..and if your girl won't mind...just take the sucker out..i did
Old Dec 5, 2001 | 06:42 AM
SpeedMonkeyRacing's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (b18b98)
screw that..AC all the way (especially when you live in jersey). I sure don't want to sit in the traffic dying cuz of no ac
Jeff-
Old Dec 5, 2001 | 07:08 AM
dbman96's Avatar
New User
Default Re: How much work is it and is it worth it to take out my A/C? (Corporal-Jeff)
I want to know what turbo is adding 100 lbs to your car!
Old Dec 5, 2001 | 07:10 AM
Rob03Pro5's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (dbman96)
I think he means his "kit." You know, intercooler, manifold, downpipe, wastegate, BOV, intercooler piping, etc. I'm sure that'll add up.. but not to 100lbs. He's just exaggerating to be funny. Dont take it literally.
Old Dec 5, 2001 | 08:46 AM
bigTom's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (Rob92SC)
u guys need to try a differant a/c system... and it weighs nothing! 2WD60!
ill be back with more info
Old Dec 5, 2001 | 09:09 AM
quick108's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (ek9t)
A/C **** only weighs 29lbs, however, I didn't take the lines or anything in the COCKpit out.
-JP
Old Dec 5, 2001 | 10:14 AM
Default Re: How much work is it and is it worth it to take out my A/C? (quick108)
Well my package from F-max weighed 88 pounds.
Old Dec 5, 2001 | 11:02 AM
rtype11's Avatar
He is running twin super thumper turbos with godzilla blow off and lead manifold.
Old Dec 5, 2001 | 12:36 PM
Damon B.'s Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (rtype11)
my package for my drag 3 weighed 60 pounds, and most of it was all that damn styrofoam (spell?)
Old Dec 5, 2001 | 01:56 PM
Doodoo's Avatar
Thats the best way to roll!! I do all year long in here in Houston!!
Old Dec 5, 2001 | 04:27 PM
AshlandSi's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (Doodoo)
I can't believe people actually take their A/C out. Dumbest trend ever. Kiss your resellability goodbye.
My Si actually came without A/C (one of the only ones that didn't have it), so I added it. I'll never own a car without it.
Old Dec 5, 2001 | 05:40 PM
bigTom's Avatar
Default Re: How much work is it and is it worth it to take out my A/C? (AshlandSi)
per request...
2WD60= 2 Windows Down at 60mph
Old Dec 5, 2001 | 06:37 PM
HXMan's Avatar
True, but who is going to want to buy a 97 Hx with an engine swap and drag III kit anyway? Probably only a kid, and a kid won't really be too worried about not having AC. I wouldn't build up a civic if I was worried about a cars resale value.
Old Dec 5, 2001 | 06:47 PM
Default Re: How much work is it and is it worth it to take out my A/C? (HXMan)
If I did it I'd save the parts to reinstall later. I don't plan on selling my car all modded out anyway.
Old Dec 5, 2001 | 06:49 PM
JimmieD's Avatar
You jackass!!! LOL i have used that system for years!!!!!! i hardly use my factory installed A/C
vtechappy
Jun 20, 2010 09:51 AM
Ej8_KiD
28
Jul 16, 2009 07:07 AM
Jose-aka-Pedro
May 14, 2007 09:46 AM
TheIntegraGuy
Jun 13, 2002 07:51 AM
98TypeR
Jun 18, 2001 07:10 PM
