a little O/T but still has to relate to turbo..
I live in socal so its really hot during the summer and I NEED A/C..After summer I'm removing all A/C components soI can make room for a 3" DP...How do you remove EVERYTHING and what belt will I have to replace to make everything work as if it were not there? Thank You..
Re: a little O/T but still has to relate to turbo.. (CustomCockpits)
You don't need to replace any belts. The P/S and alt belts will work fine without the A/C belt...
Re: a little O/T but still has to relate to turbo.. (J-MiGiRL702)
Well on my civic there was one major thing i forgot to do after removing the AC.. cover/plug/weld the hole in the firewall where the AC lines run into the car by the stock battery location.
the passenger compartment would get pretty damn hot on summers days with all the engine bay air blowing into the heater boxes and coming out the vents, which would blow right into your face!
(edit: I am a freggin typo king!)
[Modified by CustomCockpits, 7:55 AM 6/13/2002]
oh..i forgot..its a 98 civic dx... i need the ac out of the way to make room for my DP
Its not too hard to remove everything.. the only thing is to remember to cover that hole. Start with the AC compressor, then start following/removing the lines from there. Once u get ot the firewall, u dont HAVE to take apart the internals of the AC, but I did, just popped the dash off, removed the "box" thing that holds what I assume is the condenser (?) opened up that box, thru out the condenser or what ever, and put everything together.
Just amke sure u cover that hole! lol
I'm sure when I look at it itll be common sense..but is there a step by step intsruction or website that will show me how?
