VTEC WIRING
Old Dec 5, 2001 | 12:40 AM
chi1874436's Avatar
Default VTEC WIRING
I've just completed my swap and I have a bit of a small problem here. I am trying to wire up my Vtec. I have a 94 Civic Dx with an 88-91 B16a motor and using a reprogrammed P28 ecu. I know that the P28 doesn't detect a knock sensor, so I don't need to run that wire. I ran the Vtec Valve solenoid into A4, Vtec oil pressure into D6, and I am not sure where I need to run the other wires. If someone can give me a well detailed description of how the wires are ran, I will soon get started on it. Also, I am playing plug and play with running vacuum hoses correctly with the older gen b16a also. Thanks.
Pictures posted will be great.
Old Dec 5, 2001 | 02:28 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: VTEC WIRING (chi1874436)
see other post.............
Off Topic
I'm fairly new here, but do you need to post to 6-7 forums?
Not just you, but other clutch biters.
optikal_blitz
Jun 18, 2005 04:29 PM
JDM_SOHC
15
May 7, 2005 12:56 AM
Macleod95Civic
Nov 3, 2004 08:54 AM
chi1874436
Dec 10, 2001 05:38 PM
