VTEC WIRING
Old Dec 5, 2001 | 12:38 AM
chi1874436's Avatar
Default VTEC WIRING
I've just completed my swap and I have a bit of a small problem here. I am trying to wire up my Vtec. I have a 94 Civic Dx with an 88-91 B16a motor and using a reprogrammed P28 ecu. I know that the P28 doesn't detect a knock sensor, so I don't need to run that wire. I ran the Vtec Valve solenoid into A4, Vtec oil pressure into D6, and I am not sure where I need to run the other wires. If someone can give me a well detailed description of how the wires are ran, I will soon get started on it. Also, I am playing plug and play with running vacuum hoses correctly with the older gen b16a also. Thanks.
Pictures posted will be great.
Old Dec 5, 2001 | 01:31 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: VTEC WIRING (chi1874436)
if I'm sure, that is the only 2 wires you need to run.
All I needed on my Z6 SOHC VTEC into DX swap.
The "other 2 wires" are for knock sensor and GSR butterflys.
Kenji or Katman know for sure.
Old Dec 5, 2001 | 09:24 AM
RedlinedVTEC's Avatar
Default Re: VTEC WIRING (Mista Bone)
Yup just those two... oh but don't forget the ground. That should be it if I remember correctly.
Old Dec 5, 2001 | 12:33 PM
davew's Avatar
Default Re: VTEC WIRING (RedlinedVTEC)
well actually you are gonna have some problems here unless you are also running the 92-95 fuel injectors and the same distributor as well. the P28 ecu (0r any obd-1 ecu) will not run the earlier motor as the I/O on many of the sensors is different pulse widths and voltages.....
otherwise you should be set just adding the few vtec wires mentioned... and rewiring the ECT switch wich is in a different place...
good luck...
dw
Old Dec 6, 2001 | 03:31 PM
rioninja's Avatar
What he said
You can use your stock dx injectors in a -pinch- in the meantime. Just try not to take too many trips up towards 8k
[Modified by RioNinja, 7:32 PM 12/6/2001]
Old Dec 8, 2001 | 05:25 PM
chi1874436's Avatar
Default Re: VTEC WIRING (RioNinja)
I am running the dx injectors on my car because I know that the impedence level of the injectors are different compared to the older gen B16a. Also, I am running a 95 Delsol Dohc Vtec distributor with the P28 ecu. I believe what I may have been missing was the ground wire. I will check it out and see what's up. Also, may oil light stays on. However, when I check the oil, the dipstick shows that it's good. Thanks for the replies.
Old Dec 10, 2001 | 05:38 PM
davew's Avatar
oil in the pan does not = oli pressure in the motor. BIG Difference!! The light indicates pressure not quantity of oil...
dave w
B Dap
Oct 14, 2009 02:05 PM
Pfieff
15
Oct 2, 2004 12:08 PM
chi1874436
Dec 5, 2001 02:28 AM
Smashback
Nov 1, 2001 09:03 PM
