delsolb16a2 where is the fuelpump relay???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbruut »</TD></TR><TR><TD CLASS="quote">is it inside the main relay?
thanks!</TD></TR></TABLE>
The main relay IS the fuel pump [main] relay.
the main relay gives power to the ecu and to the fuel pump. I would check your grounds just to make sure. I thought my relay was bad but turns out it was a ground that i was missing.
sorry didnt know honda has got one main relay that gives power for both.
im pretty sure its the relay cause it wont start ones in a while and than ill have to try it several times.
sometimes i can hear the pump when i turn the ignition on and it stops after a few sec.(i know thats normal) then i start the engine(no pump sound or voltage when the eng. is running) and after a few sec it stals.
im afraid its going to be a expensive relay then!
