CEL: map sensor is throwin a code.
Old Aug 17, 2004 | 07:57 AM
khmboostedeh2's Avatar
Default CEL: map sensor is throwin a code.
hey guys,
my CEL has been coming on lately white boosting. i checked out what code it was and its the Map sensor. all hoses are connected, and i have it hooked up to a missing link.
will gettin a new map sensor fix this problem? can missing links go bad?
tell me everything thanks
Old Aug 17, 2004 | 08:02 AM
toolowsol's Avatar
Default Re: CEL: map sensor is throwin a code. (Jeterkm02)
i would ditch the missing link and fmu and get better fuel management, I'm guessing your map sensor is fine, who knows about the missing link
Old Aug 17, 2004 | 08:05 AM
Default Re: CEL: map sensor is throwin a code. (toolowsol)
id love to do that... but its just not realistic to me. anyway to clean or check missing link?
Old Aug 17, 2004 | 08:22 AM
Ekasey's Avatar
Do you have a v-afC? if so check the wiring my friend had the same problem and that was the cause
Old Aug 27, 2004 | 04:38 AM
TurboIntegraGSR's Avatar
Default Re: CEL: map sensor is throwin a code. (eLusive ek4)
Jeterkn02, I have been having the same exact problem, lets try to get the gurus on here.
My integra has been turbo'd for over four years, with the missing link, and have been boosting 10 psi without a problem. I just recently rebuild the head (without touching the MAP) and now it is throwing this code at boost (especially higher gears)
I am wondering if there is any way to clean the map or the missing link.. I am also going to test the MAP by swapping it out and also by reading the voltage during use..
any input from anyone with this problem is much appreciated. I do plan to go to engine management soon, but it doesnt make sense unless the car is running well with a stock ecu, i dont want my problems to compound...
Old Aug 27, 2004 | 05:04 AM
White Smoke's Avatar
i my honda
Global Mod
Sounds like the check valve
I am not sure how you could clean it?? You should be able to blow through one side and not the other! The side you can blow through should go up top. Maybe check the seals on top of and below the check valve and make sure they’re installed properly.
Old Aug 27, 2004 | 05:09 AM
underpressure02's Avatar
Before I got my ems mine would do the same thing everyone once in a while. You may want to unscrew the map sensor and see if it is dirty mine had some crap on it. I am not sure if you can use carb cleaner on it to clean it but I don't see why it would hurt it.
Old Aug 27, 2004 | 09:17 AM
Default Re: CEL: map sensor is throwin a code. (underpressure02)
Thanks guys illl let you know how it goes, si2diefor, i see we have similar taste in women, i am a big fan of vida !
Cimburke23
Sep 13, 2004 05:23 PM
TurboLude97
Apr 30, 2003 05:12 AM
Bspec18
Mar 26, 2003 11:04 PM
