5th gen SRS light
I recently crashed my 98 SH and The SRS light is on. I have replaced the airbags. I was wondering where the SRS computer is located and if I can reset it or if i must replace it.
Guest
Posts: n/a
replace the airbags or remove the srs light. When you replace the air bags Im not sure but you may have to reset the ecu. just unplug the negative batery cable and wait a minute or two and plug it back in.
Resetting the ECU won't fix it.
If you've replaced everything, you need to reset the SRS computer to turn off the light & get the airbags working again. Do a search for 'SRS reset procedures' - you should find directions posted here as well as on other forums. It's a pretty common issue/question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001 Leather Lude »</TD></TR><TR><TD CLASS="quote">But would disconnecting the negative battery cable work temporarily? If so, for how long?</TD></TR></TABLE>
Nope. Disconnecting the battery doesn't reset the SRS computer.
MonkeyPuzzle
Jul 21, 2006 04:20 AM
97V6ACCORD
Nov 17, 2002 06:26 PM
