SRS light stays on
SRS light stays on
yeah, i just bought another EG and the seller told me that the car was jump started awhile back and since then, the red srs light has been on. how do i put this light out. i've tried pulling the srs fuse and also tried reseting the ecu. neither helped so..what do you guys think?
Re: SRS light stays on (EJ8GSR)
did you try reseting the SRS light? I noticed you pulled the fuse and tried resetting the ECU...those won't usually work...the SRS system (and its own ECU) will hold memory regardless.
Re: SRS light stays on (TougeToad)
mine is on and has been on for a while, my horn also dosen't work which leads me to believe it's the cable reel inside the steering column?
Re: SRS light stays on (Grimm)
yup...if its on and the horn doesn't work, most likely the cable reel needs to be replaced. It shouldn't cost you more than $50 for a new one (search on H-T...there are some threads where people have gotten them for about $46...they have places where to get them.....i can't remember where, though).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm »</TD></TR><TR><TD CLASS="quote">mine is on and has been on for a while, my horn also dosen't work which leads me to believe it's the cable reel inside the steering column? </TD></TR></TABLE>
word...mine is doing that too! i swapped out steering columns a couple of weeks ago. i forgot to plug the SRS plug that runs to the fuse box under the dash. plugged it in and everything was coo. then a couple of days later the light is back on. two days ago my horn doesnt work. also, when i turn the steering wheels half way, i hear/feel a rubbing sound coming from the steering wheel.
I put in a new OEM steering wheel and everything worked fine for about an hour. Then the SRS light came on and my horn stopped working. Its been like for for about a year now.
Re: SRS light stays on (3 3 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 3 3 »</TD></TR><TR><TD CLASS="quote">
word...mine is doing that too! i swapped out steering columns a couple of weeks ago. i forgot to plug the SRS plug that runs to the fuse box under the dash. plugged it in and everything was coo. then a couple of days later the light is back on. two days ago my horn doesnt work. also, when i turn the steering wheels half way, i hear/feel a rubbing sound coming from the steering wheel. </TD></TR></TABLE>
SRS light, no horn, and rubbing sound all point to the cable reel. When you install a new one, you have to align it. turn it all the way clockwise and then 2 turns counterclockwise. You'll know its aligned when the little yellow mark shows in the window when the wheel is between straight and 1/3 turn counterclockwise.
MonkeyPuzzle
07-21-2006 04:20 AM
mingbling96
39
01-10-2005 08:18 PM
