HEEELP, cant boost more than 6psi!!!!!!!!
Old Dec 3, 2001 | 05:10 PM
GReddyEXcoupe's Avatar
Default HEEELP, cant boost more than 6psi!!!!!!!!
guys, I have proper fuel enrichment and timing in my greddy powered 95 d16z6
GReddy kit with BLACK (yes, black) box
If I boost more than 6 psi the CEL comes on
Can it be the MAP sensor reading too much voltage??? even when I think the black box prevents that?
Please help me, I cant wait to boost my *** off
Old Dec 3, 2001 | 05:38 PM
Smashback's Avatar
Default Re: HEEELP, cant boost more than 6psi!!!!!!!! (GReddyEXcoupe)
I think the box is only good to around 6 lbs? Not a Greddy expert, but you might need to add a missing link.
Old Dec 3, 2001 | 06:41 PM
are you guys sure?
cause the black box has a wire to the map (I think that wire is to prevent the map from reading positive pressure voltage)
Old Dec 4, 2001 | 03:29 AM
no SOHC wizards to the rescue 2day?
c´mon guys, heeelp!
Old Dec 4, 2001 | 03:38 AM
turbopanda's Avatar
Fix it the cheap way - missing link, or a whole bunch of check valves.
The expensive but sure way, do it electronically - Greddy FCD, or a ClampLink (like i'm using) - no check valves, no "missing link" - works well, and is easily tunable too (as to the maximum voltage the map sensor should send to the ECU).
[Modified by nathan's boosted civic, 7:39 PM 12/4/2001]
Old Dec 4, 2001 | 04:00 AM
D-Man's Avatar
Default Re: HEEELP, cant boost more than 6psi!!!!!!!! (nathan's boosted civic)
you need to put a check valve in the vacuum line that goes to the MAP sensor,the honda MAP will set off that light if it see boost over 6si
Old Dec 4, 2001 | 05:42 AM
VTC_CiViC's Avatar
Default Re: HEEELP, cant boost more than 6psi!!!!!!!! (D-Man)
Do yourself a favor, ditch the black box. Stick with either the GReddy blue box, or go with a manual setup, but get away from the black box.
Old Dec 4, 2001 | 05:59 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: HEEELP, cant boost more than 6psi!!!!!!!! (VTC_CiViC)
Differences in the blue and block box?
Boosthead
Jan 5, 2005 07:40 PM
Blackcivic1
Nov 4, 2002 04:03 AM
pelotudo
Aug 30, 2002 06:45 AM
1sick4door
Jan 24, 2002 07:55 PM
greyzone
Nov 16, 2001 07:10 AM
