External wastegates, why do they make more power than internals?
Old Dec 3, 2001 | 04:39 PM
meanteg's Avatar
New User
Default External wastegates, why do they make more power than internal wastegates?
But do they really do ??? and if so, why?
[Modified by meanteg, 1:40 AM 12/4/2001]
Old Dec 3, 2001 | 05:19 PM
D-SPEED's Avatar
Default Re: External wastegates, why do they make more power than internal wastegates? (meanteg)
i would think that its because a turbine housing without the internal wastegate flows more, and the fact that most people with external WGs run open loop.
Old Dec 3, 2001 | 05:21 PM
captain4g63's Avatar
They don't. On a big turbo app. they are able to limit boost were an internal gate is to small. Externals are used most often with huge exhaust and/or oversized compressor housings.
Old Dec 3, 2001 | 08:49 PM
internet ay's Avatar
Default Re: External wastegates, why do they make more power than internal wastegates? (captain4g63)
i will agree with d-speed. the fact that with a remote wastegate you have the option to run open or closed loop. if you decide to give the wastegate its own dump tube(open loop) it makes it that the wastegate has lower backpressure, making better wastegate response and it doesnt interfere with the turbine flow..so i guess you could say its more efficient, performance wise, but definately not good for economic reasons.
Old Dec 3, 2001 | 11:16 PM
BlueShadow's Avatar
captain 4g63 is correct,
WG's dont "make power" but they control boost pressure better, an internal WG is more likely to spike/creep at higher psi
[Modified by BlueShadow, 2:53 PM 12/5/2001]
Old Dec 4, 2001 | 06:27 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: External wastegates, why do they make more power than internal wastegates? (BlueShadow)
WG's dont "make power" but they control it better, an internal WG is more likely to spike/creep at higher psi
Just do a size comparison of an internal wastegate to an external, ouch!
98tegLSvtec
Jan 8, 2011 02:14 PM
gsr x civic
Apr 7, 2007 09:57 AM
EK FLY
Jul 8, 2006 06:26 AM
Btothe3rdDegree
Mar 16, 2004 12:45 PM
nolovenodie
Nov 8, 2002 02:43 PM
