will h22 vtec injector fit in my car (95civicd16z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecbOi »</TD></TR><TR><TD CLASS="quote">it seem to me that nobody on doesn't even know anything</TD></TR></TABLE>
dude, you gotta wait more than 20minutes sometimes for a reply.
the 92-96 injectors and the 97+ will both work. If you want to use the 92-96, you will need to wire in a resistor box, since they are peak and hold, where as your stock injectors are saturated. The 97+ will work, but you will need obd2 injector clips, that you will have to wire into your obd1 harness (this is easy, only 8 wires).
92-96 peak and hold - 345cc
97+ saturated - 270-290cc ( I have heard 270, 280, 290, don't know for sure.)
about the injector resistor box can you link me to a wiring diagram or a how to install? I have 440's on a 00si and I want to go bigger but I have to install a resister box. I sourced a box of a front clip that a friend of mine got the motor and trans out of and the box was left. he cut the wires about 8' away from the box and I think they are all the same except 1. I have tried a search and Im not sure how to search for that because I got zilch. Thanks in advance for your help
yes they will fit, any obd1 or 2 aren't peak and hold. lol and you don't need to buy the clips and rewire it, just take a razor blade and cut to fit, if you notice the only diff is the inside of the plug (on the injector) and the out, all you do is cut the piece that hit's and clip in and go. good luck and you don't need not freak-en resistor box.
You need a resistor box if you want them to work correctly. Also why the hell do you need 345's??? What is your setup??? Turbo, na, bottle????? Details.
nokturnal_munkeeboy
14
Apr 16, 2007 03:43 PM
Jonathan_ED3
Jun 11, 2002 10:27 AM
