Water/Air Intercooler Mixture
Old Aug 21, 2004 | 07:10 AM
Jimmy Kudo
Guest
Posts: n/a
Default Water/Air Intercooler Mixture
What is the best mixture for an Water/Air Intercooler?
Old Aug 21, 2004 | 07:11 AM
Sinner's Avatar
I've already asked this question do a search under my name
Old Aug 21, 2004 | 07:43 AM
Jimmy Kudo
Guest
Posts: n/a
Default Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">I've already asked this question do a search under my name</TD></TR></TABLE>
I looked
Thats not giving me adequate information.
Old Aug 21, 2004 | 07:50 AM
dasher's Avatar
Default Re: Water/Air Intercooler Mixture (Jimmy Kudo)
Distilled H2O
or even better...
Distilled H2O with a resevoir packed with Ice
.... answer might seem a little simple and not quite what you were looking for but it is still the correct answer.
Old Aug 21, 2004 | 07:52 AM
Jimmy Kudo
Guest
Posts: n/a
Default Re: Water/Air Intercooler Mixture (dasher)
Can I ask why distilled water is used?
Does a mixture of distilled water/ethylene glycol take heat away better than 100% pure distilled water?
Old Aug 21, 2004 | 08:03 AM
dasher's Avatar
distilled water is pure water which has a higher thermoconductivity than tap water(because of the trace minerals found present).
Water has a higher thermoconductivity than Propylene Glycol... the only reasons you use it in the radiator is because of the anticorrosive and lubricant nature and to raise the boiling point elevation/ lower the freezing point depression.
Here is another trick which would also work with an air/water as does with a radiator ... drop 1-2 drops of liquid soap in the fluid to break the surface tension.
Old Aug 21, 2004 | 08:13 AM
Jimmy Kudo
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher &raquo;</TD></TR><TR><TD CLASS="quote">distilled water is pure water which has a higher thermoconductivity than tap water(because of the trace minerals found present).
Here is another trick which would also work with an air/water as does with a radiator ... drop 1-2 drops of liquid soap in the fluid to break the surface tension.</TD></TR></TABLE>
But I said Ethylene glycol is that the same to what you said? (Propylene Glycol)
Your starting to hurt my brain what do you mean by this? (Drop 1-2 drops of liquid soap in the fluid to break the surface tension. )
<FONT COLOR="red"> What does that do? In other word that has the same affect of adding Propylene Glycol to an engines cooling fluid? </FONT>
Old Aug 21, 2004 | 08:23 AM
dasher's Avatar
Ethylene glycol and Propylene glycol are both used in radiators for the same reasons and have very similar qualities between the two.
drop 1-2 small drops of liquid hand soap in you radiator or a/w resevoir and it will break the surface tension in the water. Less surface tension means greater aluminum- water contact inside the radiator/intercooler on the molecular level... greater contact means higher thermoconductivity!
Old Aug 21, 2004 | 08:24 AM
dasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy Kudo &raquo;</TD></TR><TR><TD CLASS="quote">
no...completly different effect.
Old Aug 21, 2004 | 09:03 AM
Sinner's Avatar
i just use water some people say use water + wetter water and some say use water + alchole and some like to through a little bit of antifreeze in it just to keep the water from corroding the alumium. any TY/CY forum will have really good info on it since they have water intercooler stock.
Nick
Old Aug 21, 2004 | 09:08 AM
JSMC's Avatar
what would be a good mixture that can get to temp below zero??
Old Aug 21, 2004 | 01:12 PM
C-Zero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">i just use water some people say use water + wetter water and some say use water + alchole and some like to through a little bit of antifreeze in it just to keep the water from corroding the alumium. any TY/CY forum will have really good info on it since they have water intercooler stock.
Nick</TD></TR></TABLE>
It's not going to corrode the aluminum
Mixing the distilled water degrades and it loses its maximun performance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what would be a good mixture that can get to temp below zero??</TD></TR></TABLE>
Not with a regular water/air /radiator setup not below zero.
Only refrigerant cooled heat exchanger setups will do that.
tuerka_racing1
Oct 6, 2008 05:56 PM
titan2nv
Oct 14, 2004 06:58 PM
Sinner
Aug 25, 2004 04:11 PM
Soon_2b_evil
Jun 7, 2003 09:50 AM
Adampops
Jan 24, 2002 06:42 PM
