need help on cv boot....pppllllleeeasseeeeee (86 acccord lxi)
Old Aug 20, 2004 | 05:53 PM
winlo408's Avatar
Default need help on cv boot....pppllllleeeasseeeeee (86 acccord lxi)
k im still working on my moms 86 accord lxi, finally got the damn alternator in, and since i had to take the axle off for the alternator to come out i notice the outer cv boot ripped (damn more work), now the question is how do i put the new one on and take the old boot out, i just cant figure it out. it looks like the outer shaft thing with the little ***** slide off but its not doing it. so please i need help.
thanks for the the guys who gave me tips to take out the alternator, really helpful.
Old Aug 20, 2004 | 10:28 PM
wed3k's Avatar
Default Re: need help on cv boot....pppllllleeeasseeeeee (winlo408)
i think it would be cheaper to buy remanufactured axles, its only 50-60 bucks each when a new cv boot kit still costs 25 each.
Old Aug 21, 2004 | 12:05 AM
winlo408's Avatar
Default Re: need help on cv boot....pppllllleeeasseeeeee (wed3k)
damn, but i already bought the boot
Old Aug 21, 2004 | 01:15 AM
david90's Avatar
U need to dissemble the joint to install new boots.
If u ripped the outer boot, you would have to take out the inner boot to install new outter boot. Taking out the inner boot to install outer boot would require dissembly of the inner cv joint.
Old Aug 21, 2004 | 01:56 AM
DIYaccord's Avatar
Default Re: (david90)
Try to return the boot replacement kit...
I had my CV boot rip and just ended up replacing both axles..
goto (if you have one) CarQuest...they are the ABSOLUTE best reman. axles...only about $60 a piece
Old Aug 22, 2004 | 04:15 AM
winlo408's Avatar
the axle will be to much for me, probably later on down the road. so any ideas of how to get the outter cv joint off?
Old Aug 23, 2004 | 08:27 PM
winlo408's Avatar
Default Re: (winlo408)
okay got the joint off, now does anyone know what happens if i dont reinstall the snapring back on the shaft?
i figure the joint will not go nowhere since its connected to the shaft with splines and then its bolted tight with the axle not. if i am wrong please someone inform me.
Old Aug 23, 2004 | 10:22 PM
winlo408's Avatar
i already pulled the axle, does anyone know if the axle is suppose to be flush with the transmission or is their a little gap between them, the reason i ask this because i just put my axle back in and theirs a little gap.
Old Aug 23, 2004 | 11:40 PM
cd5_2NR's Avatar
you shouldn't have that gap in there...try again
Old Aug 24, 2004 | 12:15 AM
DIYaccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by winlo408 &raquo;</TD></TR><TR><TD CLASS="quote">okay got the joint off, now does anyone know what happens if i dont reinstall the snapring back on the shaft?
The DO move, and you DO need the snap rings, or else the axle will come out of the transmission and you'll eventually ruin your tranny or loose all your fluid and ruin your tranny
Old Aug 24, 2004 | 06:33 AM
SpeedFreak77's Avatar
Default Re: (DIYaccord)
There actually will be a very small gap between the axle and the transmission. But just a small gap.
Old Aug 24, 2004 | 06:34 AM
Default Re: (SpeedFreak77)
By the way it is cheaper and a lot less of a headache to just get a rebuilt axle and put it in. Not to mention a lot quicker.
Old Aug 24, 2004 | 11:59 AM
winlo408's Avatar
i was talking about the snapring on the outter joint and the cv shaft. and about the gap, how much of a gap?
Old Aug 24, 2004 | 12:03 PM
winlo408's Avatar
if really any gap at all?
eurochoi
Aug 3, 2012 02:50 PM
streetracerjoey210
Aug 23, 2006 09:02 PM
satintegra
Aug 9, 2002 07:26 PM
jabroni95gsr
Dec 18, 2001 08:49 AM
xtrafastcivic
Jun 17, 2001 03:23 PM
