C02 tank
Old Aug 20, 2004 | 06:03 AM
C-Zero's Avatar
Default C02 tank
I'm planning on purchasing a c02 tank and I dont know too much about the tanks but can some tell what they mean about this statement :
''Co2 15 lb.
15 lb. Brushed Aluminum Gas Cylinder - Lasts approximately 18 full kegs''
Whats that mean?
Modified by C-Zero at 7:26 AM 8/20/2004
Old Aug 20, 2004 | 06:06 AM
SpeedDreamz.com's Avatar
Default Re: C02 tank (C-Zero)
what are you using the co2 for?
Old Aug 20, 2004 | 06:09 AM
C-Zero's Avatar
Default Re: C02 tank (30psiCiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv &raquo;</TD></TR><TR><TD CLASS="quote">what are you using the co2 for?</TD></TR></TABLE>
To temporarily cool the fuel, at the begining of the fuel rail. (The intake charge also)
Modified by C-Zero at 7:25 AM 8/20/2004
Old Aug 20, 2004 | 07:05 AM
Johnyquest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-Zero &raquo;</TD></TR><TR><TD CLASS="quote">I'm planning on purchasing a c02 tank and I dont know too much about the tanks but can some tell what they mean about this statement :
''Co2 15 lb.
Whats that mean?
Modified by C-Zero at 7:26 AM 8/20/2004</TD></TR></TABLE>
It means that if you were using the c02 to pressurize kegs (of beer), it would last for approxamatley 18 kegs before it needs a refill
Old Aug 20, 2004 | 07:24 AM
C-Zero's Avatar
Default Re: C02 tank (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">
It means that if you were using the c02 to pressurize kegs (of beer), it would last for approxamatley 18 kegs before it needs a refill </TD></TR></TABLE>
Oh lol I deserved to get flamed for that, I'm not a drinker how many gallons are kegs?
Old Aug 20, 2004 | 08:21 AM
InfamousDC2FI's Avatar
haha! I was like kegs? OH KEGS! Lol Nice
Old Aug 21, 2004 | 04:16 AM
Jimmy Kudo
Guest
Posts: n/a
C02 is good for getting objects/liquid cold really fast.
Old Aug 21, 2004 | 06:33 PM
parasonic's Avatar
A "full size" half keg is 15.5 gallons.
Old Aug 28, 2004 | 09:35 AM
RnEpmc's Avatar
Default Re: C02 tank (parasonic)
if im not mistaking from my paintballin years the way they measure how much co2 is in a bottle is they weigh it. 20 oz bottle will weigh 20 oz when filled, 15 pound bottle will weigh 15 pounds when full.\
correct me if im wrong
Old Aug 28, 2004 | 11:43 PM
KaoticSnow's Avatar
Default Re: C02 tank (RnEpmc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RnEpmc &raquo;</TD></TR><TR><TD CLASS="quote">if im not mistaking from my paintballin years the way they measure how much co2 is in a bottle is they weigh it. 20 oz bottle will weigh 20 oz when filled, 15 pound bottle will weigh 15 pounds when full.\
correct me if im wrong</TD></TR></TABLE>
kinda it holds 15 lbs of co2 if you weigh the bottle before and after you'll notice a 15 lb change.
Old Aug 29, 2004 | 10:52 AM
evilone's Avatar
Modified by C-Zero at 7:25 AM 8/20/2004</TD></TR></TABLE>
make sure it can't leak into the intake!
Old Aug 29, 2004 | 09:58 PM
KaoticSnow's Avatar
Default Re: C02 tank (prostockcrx)
not a bad idea. like an ice box but last longer than ice
Old Aug 29, 2004 | 10:51 PM
90DALS's Avatar
Default Re: C02 tank (KaoticSnow)
please note. merly a 15lb bottle wont last exteremly long.
to get that "cold" effect you need direct liquid Co2. this is done by getting your co2 filled, then when spraying, turning the bottle upside down. this causes the freezing effect. also, you run out quick.
i know because i made co2 intercooler sprayer kits. a right side up co2 tank just blows mostly cool air, but upside down it delievers liquid co2 which is what we use on our intercooled setup cars.
here is a pic of what we use:
Old Aug 29, 2004 | 11:15 PM
KaoticSnow's Avatar
Default Re: C02 tank (90DALS)
most paintball stores can install a syphen in the tank to draw liquid co2 without having to turn the bottle upside down, I had one installed in my tank but had it directed toward the top of the tank so when you are playing the liquid would not be drawn just the compresed gas.
EDIT: also did you try setting up a reglator. that would alow you more time. that pic has just a valve when that is opend up it will empty your tank real quik, try installing a reg to limit the amout of co2 coming out of the tank
Modified by KaoticSnow at 8:24 PM 8/31/2004
Old Aug 30, 2004 | 08:59 AM
carbonDelSol's Avatar
That think kicks *** steve!
You going to make one of those for my SMIC?
Old Aug 30, 2004 | 09:34 AM
Code Blue's Avatar
Default Re: C02 tank (carbonDelSol)
good idea, not sure if maybe a nitrous cooler would work better in the long run eh
Old Aug 30, 2004 | 09:53 PM
90DALS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonDelSol &raquo;</TD></TR><TR><TD CLASS="quote">That think kicks *** steve!
You going to make one of those for my SMIC?</TD></TR></TABLE>
yeah, ill make you one adam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">good idea, not sure if maybe a nitrous cooler would work better in the long run eh</TD></TR></TABLE>
how much does a nitrous bottle cost to fill? right now im getting Co2 filled for 2.00 a pop, and every 10 i get filled, i get 2 free (thats a whole 4.00 savings!)
i only use it on track days when sitting in line, then going down the track. wait i wont lie, i use it all the time
boongley29
Acura TSX
25
Sep 19, 2007 01:52 PM
JDM_EK_JOE
Feb 12, 2006 05:26 PM
all_conference
67
Jul 28, 2005 02:05 PM
spoonef
Jun 25, 2005 06:13 AM
Victor Penner
10
Dec 13, 2004 02:50 PM
