89 STD hatch swapped and now...
From: 9/11/01 WTC Never Forget, United States Of America
I swapped a 93 EX Vtec into my 89 STD hatch converting to obd1
Im getting a bouncy idle (1k to 1.5k RPM's) Could someone help me out to figure whats going on...
The code Im getting goes like this:
1 quick/flash blink
4 steady
1 quick/flash blink
Someone plz help me out here
Modified by MR.RED'89 at 10:30 PM 9/14/2004
1 quick/flash blink
4 steady
1 quick/flash blink
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Mo »</TD></TR><TR><TD CLASS="quote">what was the cell code???</TD></TR></TABLE>
The CEL light just comes on'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 »</TD></TR><TR><TD CLASS="quote">I swapped a 93 EX Vtec into my 89 STD hatch converting to obd1
Im getting a bouncy idle (1k to 1.5k RPM's) and on my way home from work yesterday i got CEL
Well I took off the IACV and this thing was so damn dirty cleaned it out with throtlle cleaner and the Idle was fine for a little while and no CEL then on my way home it started acting up again same dilemma bouncy idle and CEL it just makes me nuts to hear my engine idle that way when I stop at a light
im kinda in the same dilleama but only when i have the fields controller on
i have a
90std hatch
d16z6/crx si trans
p28 ecu, obd 1 conversion harness
mine idles to 1.5 when i have the vtec controller on, the cel coems on to, u have to jump two terminals together then the cel will blink in the dash then count the blinks and you'll know the code..i dont know where they are in 89s but in 90-91s tehre supose to be by the shock tower, either u can directly make a switch to the diganostic pin and then flip that and count or find out where exatcly u jump it on 89s, because ur using a obd1 ecu now, and obd1 ecus dont have a light on the actual ecu u can count like on obd0 so u gotta jump it or make a switch
how do u like the pull? mine pulls good and i can totally her the crossover, u got a 89 so it probably pulls better than mine damn heavy 90-91s
i have a
90std hatch
d16z6/crx si trans
Cool Im gonna check that out bro...thanx
Yeah she does pull hard its a nice difference from the stock d15b1 motor
I like it the feel of Vtec........awwwwwwwwwwwwwwwwwwwww
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
Anyone plz
1 quick/flash blink
4 steady
1 quick/flash blink
Anyone plz
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
1 quick/flash blink
4 steady
1 quick/flash blink
so it is 1 flash followed by a pause and the 4 steady and flash and then pause and it starts over?
if so they are both heated o2 sensor codes. i think 1 is for signal.
fix that stuff first and see if it helps the idle. i've seen it fix idle once.
1 quick/flash blink
4 steady
1 quick/flash blink
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tom_l »</TD></TR><TR><TD CLASS="quote">
fix that stuff first and see if it helps the idle. i've seen it fix idle once.</TD></TR></TABLE>
Yeah thats exactly how the CEL flashes
I have a O2 from a EK....does that matter?
What do u mean by both heated o2 sensor codes and how can I fix it?
pin0y209
Jan 15, 2008 08:31 PM
