check engine light
Old Feb 15, 2005 | 08:02 PM
game over's Avatar
Default check engine light
i have never seen this before but, my friends car check light is on and when i went to jump it to see what code it was throwing it didnt blink! it just stays solid......what could be wrong?
Old Feb 15, 2005 | 08:06 PM
Whitfield Inc.'s Avatar
Default Re: check engine light (game over)
can't say for sure but I was told before that the ECU was bad, hope someone else can step in and help out so here's a bump
Old Feb 15, 2005 | 08:07 PM
game over's Avatar
thanks man
Old Feb 16, 2005 | 05:04 AM
JimBlake's Avatar
Default Re: (game over)
On mine, the CEL stays on solid (when jumpered) if there's no stored code. Code zero (bad ECU) is indicated by the CEL staying off.
Old Feb 16, 2005 | 04:19 PM
game over's Avatar
the CEL stays solid jumped and not jumped
Old Feb 16, 2005 | 07:04 PM
game over's Avatar
bump
Old Feb 16, 2005 | 10:19 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by game over &raquo;</TD></TR><TR><TD CLASS="quote">the CEL stays solid jumped and not jumped</TD></TR></TABLE>
JimBlake just said if the cel stays solid when jumped there are not stored codes
Old Feb 17, 2005 | 03:40 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by game over &raquo;</TD></TR><TR><TD CLASS="quote">the CEL stays solid jumped and not jumped</TD></TR></TABLE>The CEL always has power with the ignition on. When the ECU wants to turn on the CEL, it switches on the ground side of that lamp circuit.
If we knew what model or year(?) maybe someone would know what terminal # on your ECU, what color wire. Then you could check that wire for a short to ground somewhere between the cluster & the ECU. Got a multi-meter? Know how to use it?
Old Feb 19, 2005 | 06:15 PM
game over's Avatar
its a 99 si
HmgLauj69
Dec 5, 2007 09:50 AM
Extreez
Sep 22, 2007 05:43 PM
94VXLSHatchie
12
Jul 25, 2006 05:17 PM
JDM00SI
Aug 25, 2004 05:42 AM
BlkGSR
Jun 18, 2003 07:11 PM
