Wondering how to remove the stock stereo from a 92 Civic CX.
Old Aug 17, 2004 | 10:26 PM
scottpodj's Avatar
Default Wondering how to remove the stock stereo from a 92 Civic CX.
I am in the process of replacing my stock stereo with a cd player but I can't figure out how to get the stock radio out of my car. Can anyone tell me how to remove the panel surrounding the radio in order to get the stock stereo out and replace it with the new cd player?
Any help would be greatly appreciated.
Thankx,
Scottpodj
Old Aug 17, 2004 | 10:29 PM
CarsCarsCars's Avatar
Default Re: Wondering how to remove the stock stereo from a 92 Civic CX. (scottpodj)
I just replaced my stereo and im trying to remember how exactly i got the part out. Chances are I just stuck a flat piece of metal in on both sides and pulled, and the radio just slides out, not the most graceful method but it works. Really the stock radio should come out like any other aftermarket one where you just slip metal sheets on both sides and pull. You could probably use a flat bladed screwdriver if your careful.
Hope that helps.
Old Aug 17, 2004 | 10:41 PM
crashN2u's Avatar
Default Re: Wondering how to remove the stock stereo from a 92 Civic CX. (CarsCarsCars)
Did you try removing the screws holding the part of the console with the cig lighter? Remove screws, pull off the plastic and push stereo out from underneath.
Old Aug 17, 2004 | 11:02 PM
Paprika's Avatar
Check out the PDF below, you'll notice it claims to be for 93' - 95' .. I think that is a typo because it's the same exact procedure for 92' models, cause I have one:
http://www.installdr.com/Insta...7.pdf
Also, note that they mention you need to undo some screws that hold the radio in place, i found my radio was not held in with screws at all and I could have pulled it out without taking off the bottom panel by putting my finger in the tape door and pull on the face of the Radio... Try that, not too hard though.
Old Aug 17, 2004 | 11:14 PM
crashN2u's Avatar
Default Re: Wondering how to remove the stock stereo from a 92 Civic CX. (Paprika)
Yeah the stereo in my 94 cx or 93 si didn't have any screws holding the radio in.
Old Aug 19, 2004 | 09:54 AM
Default Re: Wondering how to remove the stock stereo from a 92 Civic CX. (crashN2u)
Paprika is right its how i removed my stereo i pulled it out by putting my hand in the tape deck and it just slid out. Though im not really sure why there were no screws if there supposed to be there..... oh well.....
SHG_Claudio
Jul 8, 2009 05:58 PM
scottpodj
Audio / Security / Video
Aug 18, 2004 02:44 AM
92accrdLX
Aug 5, 2004 07:45 PM
ForceXVII
Aug 23, 2003 11:10 PM
stevie_h
Aug 10, 2001 11:31 PM
