HOw to remove stock cd player?
Old Aug 22, 2003 | 03:50 PM
ForceXVII's Avatar
Default HOw to remove stock cd player?
I got a 95 accord EX w/ stock cd/cassette player. Im having a verryyy difficult time removing it. Does anybody know how to remove it? THx
Old Aug 23, 2003 | 10:34 PM
integra72's Avatar
Default Re: HOw to remove stock cd player? (ForceXVII)
empty your arm rest console pull pannel on the bottom 2 screws
pull the drink holder 3 screws slide armrest back 2 screws on black pannel under armrest you just removed pull ash tray 1 screw behind that
easily pull on black pannel 2 clips holding in top they will pop out with pressure
2 silver screws and the radio is out
sounds like a lot of work but if you print this and can turn a screwdriver the radio will be in your hands in 15 minutes
if you are puttins in an aftermarket radio while you are going put it all back together because the kit mounts through the front of the black pannel so you have to put it all back leaving a big hole in the dash
been doing this for 15 years you will be fine
30 minutes from begining to end
have fun
Old Aug 23, 2003 | 11:09 PM
ForceXVII's Avatar
Default Re: HOw to remove stock cd player? (integra72)
THanks for the info. THe reason I need to take it out is because I need the dealer to give me the code. Do you know about the code that shows inside the deck? Thx
Old Aug 23, 2003 | 11:10 PM
integra72's Avatar
it is not the code you will get on the radio you need the serl# and your vin# when you call the dealer
SHG_Claudio
Jul 8, 2009 05:58 PM
dubkatz
Audio / Security / Video
May 24, 2008 09:41 AM
jim109
Oct 16, 2006 05:28 AM
ITR0952
Sep 11, 2004 03:11 AM
ajd2004
Aug 24, 2004 08:06 AM
