QUATER MILE TIPS!
Old Aug 17, 2004 | 08:51 PM
Hatch It's Avatar
Default QUATER MILE TIPS!
I dont know where this belgongs but a moderator will help
Ok so im going to the track tomorrow, for the first time. I need tips and/or help on what to do how high to rev and all the good ****.
Please help me out quick, thanks
Old Aug 17, 2004 | 08:52 PM
handa's Avatar
Default Re: QUATER MILE TIPS! (Cons94)
first, what are your setup?
Old Aug 17, 2004 | 08:58 PM
Hatch It's Avatar
Default Re: QUATER MILE TIPS! (handa)
mostly stock D16Z6 intake exhaust short shifter headers, nothing much
Old Aug 17, 2004 | 09:04 PM
jerbear!'s Avatar
make sure that u have some tires that grab pretty good. if so launch pretty high ike around 5-6k. with a setup like that since you arent making that much power u can jus launch and fully dump the clutch. then try not to let your rpm's drop. then after that... shift like a ****
Old Aug 17, 2004 | 09:14 PM
handa's Avatar
Default Re: (jerbear!)
it'll depend on your setup. from those mods you have, it's much like my old d16z6 when i used to have it. i rev 5-6k rpms on the launch because my clutch was pretty bad and my rpm dropped a little. don't let your rpm drop too much or else you won't have a good launch.
try practicing some launches somewhere open, get the feel of how high rpm you should launch at, then you can see how.
Old Aug 17, 2004 | 09:18 PM
j0nptw's Avatar
Default Re: (handa)
in my D16Z6, i have exhaust/header/short throw shifter. I launch right around 5k, usually never below. If i don't feather the clutch out just a little bit i get some tire spin but nothing too bad. just practice and you'll be fine.
Old Aug 17, 2004 | 09:23 PM
Hatch It's Avatar
Default Re:
what do you mean RPM drop? but thanks for the quick help guys, i appreciate it alot
Old Aug 17, 2004 | 09:34 PM
Street Ghost's Avatar
Default Re: Re: (Cons94)
Lower your tire pressure to about 20-22 psi. I did that, and launched at about 4,000 - 4,500 rpm and pulled like a 2.32 60'. Ended up running a 15.908@84.xx mph in a stock D16Z6 motor EX Coupe.
Old Aug 18, 2004 | 01:27 AM
jdmh22eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cons94 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean RPM drop? but thanks for the quick help guys, i appreciate it alot </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cons94 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean RPM drop? but thanks for the quick help guys, i appreciate it alot </TD></TR></TABLE>
it means to stay in the sweet spot...
Old Aug 18, 2004 | 05:11 AM
99CivicExCoupe's Avatar
bump for good info
Old Aug 18, 2004 | 09:02 AM
hondainspired's Avatar
**** i used to have the best write up for beginers....!!!
I can tell you not to go all out your very first time... just get a feel for things... and make sure you make the turn off... know where that turn off is... and dont ever crose into somones turn off... if theres only one turn off let the person on the side of it go first...
just use common sence and be safe...
Old Aug 18, 2004 | 09:51 AM
splitime's Avatar
Default Re: Re: (JDM Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja &raquo;</TD></TR><TR><TD CLASS="quote">Lower your tire pressure to about 20-22 psi. I did that, and launched at about 4,000 - 4,500 rpm and pulled like a 2.32 60'. Ended up running a 15.908@84.xx mph in a stock D16Z6 motor EX Coupe.</TD></TR></TABLE>
He'll be looking at more like 16-17+ if not slower... with all that stereo and body kit stuff.
BTW: isn't that the car from the audio shop in exton?
Old Aug 18, 2004 | 10:00 AM
Default Re: Re: (splitime)
gotta take me ex coupe to test and tune before the season is over...
Old Aug 18, 2004 | 10:38 AM
Hatch It's Avatar
Default Re: Re: (hondainspired)
yes it is the same car as in audio sensations in exton, you familiar with it?
Old Aug 18, 2004 | 11:15 AM
Xander teh Grate!'s Avatar
I love beating gay looking civic's like yours at the track with my 92 turbo 4 door LX. Should have put the money into the engine not the stunna paint job and body kit.
TypeRlove
Apr 19, 2005 07:38 PM
AllMotorMark
53
Sep 13, 2003 05:35 PM
J.D.M.
Jul 9, 2003 02:21 PM
95integrags-r
May 8, 2002 11:56 PM
