help with launch
Old May 8, 2002 | 10:02 PM
95integrags-r's Avatar
Default help with launch
I was trying to do some lauches with my new things. I would rev to bout 4 then drop clutch, it would hiot redline, I would **** to 2nd, then the speedometer would jump to like 50 or 55, but then it drops to like 30 or 40. once I kept the speedometer up but I dont really know how I did it. so, what do you rev to and when do you shift to second???
thanks
Old May 8, 2002 | 10:09 PM
strils's Avatar
Default Re: help with launch (95integrags-r)
i rev to 4000 also and shift right before 8000
Old May 8, 2002 | 10:12 PM
Default Re: help with launch (strils)
like when it is in first shift right before 8000??? or always?
Old May 8, 2002 | 10:33 PM
dubster99's Avatar
It bogs because you are spinning all the way to redline, then you hit 2nd and hook up but aren't going fast. Dump it from 4k, then feather the gas until the tires hook up. That'll work better.
Old May 8, 2002 | 10:36 PM
Default Re: help with launch (dubster99)
thanks, that sounds like what I did the time I did it good.
Old May 8, 2002 | 10:39 PM
SIK IN DA HED's Avatar
New User
tach it to 3500 and drop it. dont let go of the clutch too fast cuz then your tires are gonna spin like crazy and youre goin to be "floatin" before your clutch grabs and spins your wheels. then... shift to 2nd at 7000 and just gas the **** out of it before redline.
Old May 8, 2002 | 11:56 PM
rodimus's Avatar
Default Re: help with launch (dlplayboy)
in drag racing for a GSR...mine having only an icebox intake..
whats the optimal shift point in each gear?
soon2bdropped
Jun 15, 2005 09:56 PM
TypeRlove
Apr 19, 2005 07:38 PM
TeamTooQuick
Jan 26, 2003 08:12 PM
