Gauge lights
So tongiht after installing my new sound system my gauge lights dont work anymore, i may of blown a fuse or something. Anyone know which fuse it is or what the problem could be?
okay i guess you put in a cd player or some type of head unit. there is a 2 wires back behind it. one is a illumination wire the other is a dimmer wire. one of those wires are proboly grounded which cause your fuses to keep blowing. plus your dash lights and other interior lights are wired into or though these wires also. so check that and you should tape up ANY bare wires. after that you should be good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 »</TD></TR><TR><TD CLASS="quote">Check your ground for your stereo. Did you put an inline fuse between the battery and your amp/ distribution block?</TD></TR></TABLE>
most any new stereos have a fuse built into the back of them. plus the fuse in the fuse box is protection enough. the fuse between a amp and your battery is just protection for your car. those fuses on the side of the amp are what protects your amp from a overload.
abusedvtec
Apr 28, 2008 10:32 PM
EF4lyfe
19
Sep 27, 2004 08:43 AM
