Anyone with a VAFC, whats your vacuum readin (MAP) at idle?
Old Aug 17, 2004 | 03:34 PM
MattD@Stoptech's Avatar
Default Anyone with a VAFC, whats your vacuum readin (MAP) at idle?
Thanks in advance.
Old Aug 17, 2004 | 03:39 PM
Doctor CorteZ's Avatar
Default Re: Anyone with a VAFC, whats your vacuum readin (MAP) at idle? (El Pollo Diablo)
in mm/hg ? what cams Yo ?
Old Aug 17, 2004 | 03:40 PM
Default Re: Anyone with a VAFC, whats your vacuum readin (Doctor CorteZ)
mm/HG, PSI, whatever, i can convert
I'm running C's.
Old Aug 17, 2004 | 03:41 PM
DsITR's Avatar
ok..
My idle was @about 900rpm (w/minor fluctuations)
MAP was ~-580 mm/HG (w/minor fluctuations)
Car was cold and just started. After it warms idle drops to around 800rpm.
...hope I did that right
car is a 97 R w/13k. All stock except for JDM DC, 2.5" exhaust/cat.
I'm in UT incase elevation somehow effects that figure If you need anything else lemme know
Old Aug 17, 2004 | 03:45 PM
Default Re: Anyone with a VAFC, whats your vacuum readin (DsR)
hmm...so if i'm seeing -9.2 psig something is prolly not right...
(~475 mm HG)
Thanks, btw.
Old Aug 17, 2004 | 03:48 PM
DsITR's Avatar
Default Re: Anyone with a VAFC, whats your vacuum readin (El Pollo Diablo)
BLAH, nevermind the figures below are for fuel pressure
possibly.. I was looking for a spec reading in the helms.. no dice.
EDIT I'm kinda new to this concept soo.
MAP= manifold absolute pressure right??
In the helms it does state the following. It's in fuel and emissions sec 11, in the Type R supplement. But right now I'm thinking this isnt the MAP, correct?
just in case, here's the specs
Pressure w/regulator vacuum hose disconnected
kPa (kgf/cm`2, psi)
320-370 (3.3-3.8, 47-54)
soo
kPa (kilo pascals') can range from 320-370
kgf/cm`2 can range from 3.3-3.8
psi can range from 47-54
I'm assuming elevation can't effect that figure because the environment is basically sealed, right?
Old Aug 17, 2004 | 03:49 PM
well, my cams could play a huge role in this....the problem is me mostly, cause i can't figure out if I used to see lower readings or not....
i'm prolly stressing over nothing and it's as it always was, and I'm positive I don't have any vacuum leaks.
Ok, found some old datalogging graphs, my idle vacuum used to be -10.4 psi which is about 540 mm HG, but the cam gears were tuned back then...
*scratches head some more*
Modified by El Pollo Diablo at 8:00 PM 8/17/2004
Old Aug 17, 2004 | 03:54 PM
C's should run around .3-.2
my little oem's run at .5 all day.
Old Aug 17, 2004 | 03:59 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
hrm.. I wonder if I let the car warm if the values would change.
I'm a definite n00b hear, but if cams could effect this value, cam gears could as well... no?
Old Aug 17, 2004 | 04:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsR &raquo;</TD></TR><TR><TD CLASS="quote">hrm.. I wonder if I let the car warm if the values would change.
I'm a definite n00b hear, but if cams could effect this value, cam gears could as well... no?</TD></TR></TABLE>
yes, cam timing will play a role. So I could, technically, be stressing over nothing (and prolly am)....but better safe than sorry.
Old Sep 19, 2004 | 11:04 PM
JDM KING's Avatar
hmm im having problems with my map and vafc too....im runnin s2s2's can anyone help...i disconnect the map and the car still runs....wtf? its runnin way to rich too. can anyone help?
Old Sep 20, 2004 | 06:06 AM
Pondus's Avatar
-11.5 psi @ 800rpm, stock internals, B18C6 engine.
Old Oct 22, 2004 | 05:33 AM
Black R's Avatar
25 Year Member
I hope this helps:
https://honda-tech.com/zerothread?id=212783
FERIOkid
Nov 11, 2006 04:07 PM
IVI
May 24, 2005 03:47 AM
IVI
27
Aug 29, 2004 09:27 PM
Nerologic
Oct 4, 2003 11:03 PM
asianspeed
Feb 25, 2003 07:19 PM
