Tial Wastegate settings
Old Aug 14, 2004 | 02:32 AM
toxicshit's Avatar
Default Tial Wastegate settings
Hi people,
I have searched the site of tialsports.com but ist a lame site.
i have the 38 mm tial wastegate how can i see wich spring im using ( i bought the Wastegate used ) and the previous owner doenst know.
Available spring pressure: .25Bar (3.63 psi), .4Bar (5.80 psi), .5Bar (7.25 psi), .6Bar (8.70 psi), .7Bar (10.15 psi), .8Bar (11.60psi), .9Bar (13.05 psi), 1.0Bar (14.50 psi) i know that there are these springs.
I have a Manual Boost controller ( Festo Manual Air regulator Valve. ) when i connect it between the top air niple and the niple in the side. shoud i screw the controller almost shut ( minimul air passage ), or shoud i screw it open ( no air restriction maxumum air ). to set the wastegate the the minimum boost ?
Greetz Erwin
ps. sorry for my bad english.
Old Aug 14, 2004 | 04:20 AM
eg6T's Avatar
Default Re: Tial Wastegate settings (toxicshit)
dont open it up all the way.you will boost a crap load.lets say you have a .5 bar(7.25 psi),with a boost controller you cant go below 7.25 psi,you can only make the psi go higher,so if you let maximum air in you will boost whatever your turbo can handle,which your engine probably wont be able to handle.so 7.25 psi is the minumum psi.try closing all the way and see what your boost gauge reads...that should show you what spring you have.also you can open the wg and the spring will have a color.i think these are right but im not sure.... .25bar=yellow,.4bar=red,.6bar=blue ...not sure of the others........hope this helped.....and if im wrong on any of this please correct me
Old Aug 14, 2004 | 06:24 AM
toxicshit's Avatar
Default Re: Tial Wastegate settings (eg6T)
ye sthat helped so if i place a manual air regulater i should screw it almost shut and from there i should open it to set the boost level.
and thnx for the spring colors :D
greetz Erwin
Old Aug 15, 2004 | 12:14 PM
eg6T's Avatar
glad it helped.when you start to open it,start opening VERY little each time.good luck
turbo-crx
Sep 6, 2009 12:12 PM
afrothunda713
Jul 10, 2006 09:40 AM
KStuned
Dec 8, 2003 11:52 PM
275Performance
Sep 14, 2002 12:24 PM
Downey
Aug 7, 2002 04:12 PM
